Author Topic: Front turn signals on a 67..  (Read 3567 times)
snap on pete
« on: November 19, 2015, 05:03:59 PM »
So the newly purchased 67 is being loaded as we speak and will soon be on the sea to me..
In the meantime i was wondering re the turn signal lights..
The front of my 67 is fitted with the 4 lights...   Just wondered  where they are installed ?
Would anyone be able to do a short video of theirs to show me??
Thanks  Pete..
1968 Z28
Re: Front turn signals on a 67..
« Reply #1 on: November 19, 2015, 05:16:30 PM »
The two inner lights are a combination turn signal and parking light.  The bulb inside the assembly is a dual element unit that performs each function.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
snap on pete
« Reply #2 on: November 19, 2015, 05:23:49 PM »
Ahhhh   thought that might be the case..  Thank You
L78 steve
« Reply #3 on: November 20, 2015, 12:51:41 AM »
How do you deal with the left hand drive? Does it have to be converted as in AU?
69 Z/28 Dover White. SOLD
snap on pete
« Reply #4 on: November 20, 2015, 02:01:44 PM »
Hi Steve
Yes not a problem, you just get used to it..  Only problem is overtaking i guess.  But the secret there is to hang back a bit
so you have a clearer view of the road..
No, no conversions needed.
Once the car arrives, We have a roadworthy test called an MoT...which is quite strict i guess.   I tend to use a local garage which is
`Classic` friendly..
Post 1965 should have amber indicators to the rear and front, and at a certain `flash rate`..  The main beams need adjusting the other way
but thats about it...  Most of the garages havent seen USA Classics so its a grey area ?
Have had 2 over now.  57 Chevy Stepside and my last one have just sold a 67 Mustang Fastback.
The Camaro should arrive UK mid Dec..  Then once MoT is carried out i can apply for Registration.
I guess by then there will be salted roads over here...So wont be going far until Spring.. but will be an early start with
the shows..
all the best  Pete
