Author Topic: Is this rear axle original to my car?  (Read 14305 times)
HustleRussell
« on: November 18, 2015, 09:29:39 PM »
Rear axle  is 3:31 12 bolt date code march 3. Trim tag 02d. VIN  124379N610048.
Russ
68 RS
69 SS
HustleRussell
Re: Is this rear axle original to my car?
« Reply #1 on: November 18, 2015, 09:31:10 PM »
Tag
Russ
68 RS
69 SS
HustleRussell
« Reply #2 on: November 18, 2015, 09:31:53 PM »
Axle code.
Russ
68 RS
69 SS
« Reply #3 on: November 18, 2015, 09:46:36 PM »
Your car was final assembled on or about Wednesday March 5. The axle plant was about 260 miles from Norwood. Possible but it's a real stretch.
« Last Edit: November 19, 2015, 12:07:49 AM by william »
« Reply #4 on: November 19, 2015, 07:05:47 AM »
I definitely think it's original. :)
That's based on data from other cars built at the same time.
« Reply #5 on: November 19, 2015, 03:52:52 PM »
I would have thought that axle date would have been too close to vehicle assembly - but there are a few other cars with very "tight" axle dates around that time.
Definitely not the "norm". Must have gone almost right from the train into that car. 😀
HawkX66
« Reply #6 on: November 19, 2015, 05:12:27 PM »
My born with axle is 08/20/69 and my final assembly date is 08/22/69.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
HustleRussell
« Reply #7 on: November 21, 2015, 01:10:00 PM »
Thanks for all the input. Nice knowing complete drivetrain is original.
Russ
68 RS
69 SS
« Reply #8 on: December 01, 2015, 03:48:23 PM »
That's the same rough number of days between assemblies, but not likely the normal spread across the board.  More common axle ratios often have dates close to car assembly date.  But even that will vary through the year.   My early 68 has about a one month separation, but that's a 3.73 rear and not a lot were produced early in the 68 model year.
« Reply #9 on: December 02, 2015, 06:55:18 PM »
My '69 02D car (606402) was built about five days ahead of yours - mine was shipped on February 28th, and the "BV" axle is dated February 19th.
cruizin69
« Reply #10 on: May 20, 2016, 06:17:58 PM »
The car build date is 02D fouth week of Feb.
Axle build date is 0303 March 3 does that not make the axle build date about a week after the axle build date?
« Reply #11 on: May 20, 2016, 07:10:36 PM »
Fourth week of February is when building of the car STARTED.
Read the other posts in this thread - please. :)
« Reply #12 on: May 24, 2016, 12:54:23 PM »
Axle dates seem to be the closest to vehicle assembly.
The 10D 69 Z I restored had a 11A Vin and a 10 31 axle date.
« Reply #13 on: May 24, 2016, 02:39:20 PM »
It depends a lot on ratio and dates are not ALWAYS close. There is variation.
« Reply #14 on: May 25, 2016, 03:36:47 AM »
Depends on when. Mid-69 axles are very close to the build date. Other times, dates are more spread out.
