Author Topic: correct vinyl top glue pattern  (Read 6163 times)
aaronz28
« on: November 12, 2015, 03:44:34 AM »
I can't seem to find any info on this -
but every original vinyl top i've seen has a "checker board" pattern visible - which i believe has to do with the way the glue was put on...
has anyone successfully recreated this on a newly installed top?
69pace
    • TeamCamaro - Moderator
Re: correct vinyl top glue pattern
« Reply #1 on: November 12, 2015, 05:17:14 PM »
Wow. My 72 Impala had a vinyl top and when I removed it the glue pattern looked like rows of figure eights overlapping side and bottoms. Figured it was laid out by hand. Wonder if the checker board was already on the vinyl and some how activated maybe a heat process?
aaronz28
« Reply #2 on: November 12, 2015, 06:19:18 PM »
seems like the checkered pattern is in the vinyl itself, not the glue :D
HawkX66
« Reply #3 on: November 12, 2015, 07:46:12 PM »
I can't say that I recall any checker pattern on my vinyl top... Glue or otherwise.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
lakeholme
  • 68-12D L30/M35
« Reply #4 on: November 12, 2015, 07:54:40 PM »
X2
I've looked at a lot of vinyl tops, and never noticed such a pattern -- in glue or material
Could you post a picture of what you are talking about?
It would be great if someone like JohnZ could tell us the how, when and where about vinyl top placement at the factory...
aaronz28
« Reply #5 on: November 12, 2015, 08:31:38 PM »
sure - watch this video -  its short - but you can clearly see a checkered pattern in the vinyl... this is a replacement top -
i've since learned that its not the glue - but in the vinyl itself - something bout the machine that puts the grain into the vinyl...
i had previously only noticed it on my original vinyl top cars- which is why i assumed it had to do with the factory glue, or install process - but i was wrong..
it seems that of all the manufacturers of replacement tops - only a few make them correctly to get the correct appearance -
https://youtu.be/SYT8K_QT4f0
cheers
« Reply #6 on: November 12, 2015, 09:20:04 PM »
 Patterns are on original tops and cannot be seen on old, weathered tops. It has nothing to do with adhesive application.
