Author Topic: BB manifold still tapping PS box  (Read 27712 times)
sixt9x33rs
Re: BB manifold still tapping PS box
« Reply #15 on: November 11, 2015, 03:05:38 AM »
Two questions:
1- "....but still have this annoying bumping of the manifold on the ps box."
   Judging from the above comment I assume this always occurred? Yes I had the incorrect non smog manifolds on the car which I thought was the source of the problem. I bought these manifolds and the issue was still there. I bought new motor mounts and put them on. It helped the issue but still there.
2- Does the fan look centered (Horz. and Vert.) inside the shroud or does it look off to one side. Hard to tell the car is on the lift and another under it, but I did look up in there and it looked centered. I did notice the bottom of the shroud is broken out.
sixt9x33rs
« Reply #16 on: November 11, 2015, 03:07:31 AM »
Can someone do me a a favor and snap a picture of correct distance between the manifold and the steering box?
sixt9x33rs
« Reply #17 on: November 11, 2015, 03:43:26 AM »
Did you measure the height of your engine mounts? You said you confirmed they're the correct frame stands too right? I have headers and even they aren't that close.
Starting to second guess the frame stands again...
« Reply #18 on: November 11, 2015, 04:20:47 AM »
 The frame mounts should have a part number on one of the flats.
 I wonder if you have 67-68 frame mounts instead of 1969.
sixt9x33rs
« Reply #19 on: November 11, 2015, 12:08:37 PM »
I checked the part numbers and they are what is listed for 69 BB per this site. But this can't be that complicated...it must be the stands?
HawkX66
« Reply #20 on: November 11, 2015, 12:25:58 PM »
Just put a measuring tape to them and compare it to the measurements listed on the site. That's the only way you'll really know.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
sixt9x33rs
« Reply #21 on: November 11, 2015, 01:12:13 PM »
Yep getting ready to go do that.
sixt9x33rs
« Reply #22 on: November 11, 2015, 02:47:33 PM »
Measured the stands the best I could and the passenger side stand is about .25 inches taller. I had also checked the part numbers on the stands a few months ago and they were correct.
Can someone post a picture of the correct distance between the manifold and the steering box?
L78 steve
« Reply #23 on: November 11, 2015, 06:13:36 PM »
I will take a pic. tonight. Its a 70 Nova but will be the same.
69 Z/28 Dover White. SOLD
L78 steve
« Reply #24 on: November 12, 2015, 12:44:05 AM »
The space between the box and manifold is about one inch.
L78 steve
« Reply #25 on: November 12, 2015, 12:54:29 AM »
If the stands are re-pops they are not technically correct.
« Reply #26 on: November 12, 2015, 02:19:45 AM »
Pics of the 941-942 NOS frame stands, I will measure for you if you need a comparison to yours. LH is noticeably taller - may be the problem. I had a pair of '68's that I traded off a longtime ago - definitely different heights -
sixt9x33rs
« Reply #27 on: November 12, 2015, 02:59:44 AM »
Thanks L78 Steve that gives me a good reference. Based on that I would have to assume the driver side frame stand is wrong? Not sure what else it could be?
sixt9x33rs
« Reply #28 on: November 12, 2015, 03:02:50 AM »
[/quot
If you don't mind measuring for me that would be helpful.
HawkX66
« Reply #29 on: November 12, 2015, 01:07:24 PM »
I don't have a pic with factory manifolds, but here's a couple decent pics of mine that show the height difference well and also the correct factory part number on the driver side. I also included measurements that I picked up off someone's thread a while back.
Dave
Semper Fi!
