Author Topic: 69 z11 wiring fault  (Read 5426 times)
sebs
69 z11 wiring fault
« on: October 31, 2015, 02:32:49 PM »
hi i wonder ifr anyone out there can help,ive got a unrestored z11 auto ,when the ignition is switched on ,the purple wire on the main junction box on the firewall over heats and starts to smoke ,if i turn the engine over a few times it over heats more and then will not engage the starter,wiring is standard but it has been changed from column to floor shift with a counsol fitted many thanx to anyone giving advise
Re: 69 z11 wiring fault
« Reply #1 on: October 31, 2015, 02:59:15 PM »
Sounds like a poor ground. Is the shifter harness properly grounded to the floor pan?
« Reply #2 on: October 31, 2015, 06:58:13 PM »
Or...when 'juice' (batt.) is applied to wire by turning on ignition, that purple wire is directly shorting out to a grounded surface.
sebs
« Reply #3 on: November 01, 2015, 12:16:50 PM »
well worth a look ,fingers crossed ,many thanx
jdv69z
  • 69 RS Z/28 52E
« Reply #4 on: November 01, 2015, 04:29:36 PM »
I'm guessing short? With the ignition off, try using a meter on ohms setting between the purple wire and ground. You should not get anything ie no connection. If you get a connection, ie 0 resistance, you've got a short.
Jimmy V.
« Reply #5 on: November 01, 2015, 06:41:40 PM »
That purple wire goes from the ignition switch (and the neutral safety or clutch safety switch) directly to the small "S" terminal on the starter solenoid, and isn't involved in any other circuits; somewhere between the ignition switch and the starter solenoid, that purple wire is chafed and/or shorted to ground.
« Reply #6 on: November 01, 2015, 07:22:41 PM »
I think I read that somewhere?
