68CamaroZ28 -
I can see a few differences in yours vs. mine
1) the underside surface for the "out" line mounting area is much smaller on yours, looks to be about 1/8", whereas the underside on mine is about 1/4", which to me would indicate that your valve is fatter than mine
2) the machined area around the nut, the step between the machined area and the rough casting, looks to be larger on yours then on mine, which would speak to a fatter valve
Since my car is a fairly good example of an original survivor, along with your pics of the fatter valve, I'm going to assume that mine is the origina, or at least correct, metering valve.
The proof will be when I receive the rebuild parts.
Thanks...
Chris
