Author Topic: firewall chalk - how did this look originally  (Read 21038 times)
Mark
Re: firewall chalk - how did this look originally
« Reply #15 on: October 27, 2015, 02:43:24 AM »
Generally if its on top of the firewall blackout its Chevrolets markings, below the blackout its Fishers and obviously it belongs right where you have it..
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Steve Shauger
    • Vintage Certification
« Reply #16 on: October 27, 2015, 10:28:33 AM »
My firewall had "BBLU" written on it. Guessing it stood for big block & Le Mans blue??
BBLU=BRIGHT BLUE/ Lemans Blue
Steve Shauger
rich69rs
  • LF7/M35/Z22/Z87
« Reply #17 on: October 30, 2015, 05:02:18 AM »
Only firewall marking found on my Norwood '69RS back in 2004 was what looks like a "2" that was not visible until the LH fender was removed.  Have never found an explanation, but it was clearly there.
Richard
Richard Thomas
1969 RS
« Reply #18 on: January 28, 2016, 05:07:49 AM »
I have only seen color indications over the top of the first black and on the car before paint.
LA Car... unrestored   since LA was multiline I have found they use codes instead of descriptions of colors...  71 here in yellow grease pencil
dalealan
« Reply #19 on: July 18, 2016, 05:06:55 PM »
Here are the marks that were under the A/C box onmy 68RS. There were also chalk marks on the inside of  the lower valance panel.
« Reply #20 on: July 20, 2016, 05:27:00 PM »
Dave Beem's survivor No stripe Silver 69 RS/Z with - -  has 69 on the firewall.
So obviously the color is Cortez and the - - was for NO STRIPE.
« Reply #21 on: July 21, 2016, 04:05:42 AM »
I don't think it's that obvious. ;)
-- meant see instructions. Could be a different color stripe, no stripe, etc.
« Reply #22 on: July 21, 2016, 07:02:07 AM »
Kurt,
Sorry I was not clear...
I meant on that particular car... since there is a 69 on the firewall and the car has original paint sans stripes.
« Reply #23 on: July 21, 2016, 04:38:57 PM »
Got it. I read it a different way.
Oaklyss
« Reply #24 on: August 05, 2016, 07:31:25 PM »
I have yet to see anyone able to copy the style of writing on the firewall in the same smooth way the assembly line workers did. And yes, its under the black out not on top.
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built-SOLD
1968 GTCS mint unrestored original paint
1972 AMX 401 4 speed, cowl induction, twin-grip, A/C, unrestored, original paint
1963 Oldsmobile Jetfire factory Turbo and Methanol injection, 4 speed, posi, 1 of 4 known to exist
« Reply #25 on: August 06, 2016, 03:11:40 PM »
you have to spend time trying to replicate arm motion in order to get them to look "more" correct... think about the limited amount of time they had to make the markings...
This is an engine compartment done which has partial original paint (inner fenders brackets etc) and the firewall was redone to match the patina of the other unrestored parts. All of the phosphate and bright zinc were original.
« Reply #26 on: August 06, 2016, 04:15:53 PM »
James where did you get the rad hoses for that cortez vert??
« Reply #27 on: January 13, 2019, 02:13:44 AM »
Lawrence got the hoses from Pace Car Jeff.
http://www.hendrickperformance.com/detail-1969-chevrolet-camaro_ss-used-15619172.html
FWIW the car is for sale at Rick Hendricks. and has since been certified by Jerry.
In his report Jerry unknowingly paid me one of the biggest compliments I think I have ever received...
Engine Bay - very good, minor replacement components, engine bay is very original.
I completely restored the engine bay - There is not one surface which was not touched...
ALSO In addition to cutting the overlap off and butt welding the upper seam of the overlapped bondo'd in Quarter panels, I sectioned in part of the rusted dash at the windshield base, sectioned in both rear wheel houses, and a sectioned in a drivers rear 1/4 panel trunk drop.
« Reply #28 on: January 13, 2019, 05:07:48 AM »
Congrats James!  :)
that sames a lot more for your 'restoration/preservation' efforts than it does for JM's 'assessment'...  :)
« Reply #29 on: January 13, 2019, 05:40:17 PM »
Very nice work James. I also thought it was interesting that the LA car did not have an emissions sticker, since California was probably one of the few states where you had to keep the smog pump on, and enforced the smog rules for years.( unless you knew a guy that could get you an illegal smog...😏)
