Author Topic: Holley Accelerator Pump Tool  (Read 4164 times)
dannystarr
« on: September 28, 2015, 06:33:34 PM »
Where can I get that special tip tool to remove the accelerator pump screws on my 4150 Holley carb? I looked everywhere online. Anybody have a part number. I could switch it out to a Phillip's head, but trying to keep it as stock...Can't find it on Amazon, eBay, or even a google search... WTF... D
Re: Holley Accelerator Pump Tool
« Reply #1 on: September 28, 2015, 06:46:33 PM »
Its called a clutch head screwdriver bit.
http://www.amazon.com/STANLEY-Clutch-Head-Bit-Screwdriver/dp/B005SG1QU4
http://www.amazon.com/Piece-Clutch-Head-Screw-Driver/dp/B007ZS38PO
Or take a flat head and cut it down to fit the slots.  Done it both ways.
« Reply #2 on: September 29, 2015, 07:01:51 PM »
The first time I encountered them, I ground and filed an old phillips head that was worn until it fit. It works in a pinch, just ensure the tool will seat and doesn't rock back and forth.
little_hoss
« Reply #3 on: September 29, 2015, 08:22:51 PM »
Got mine from Sears about a year ago in one of their bit driver sets because I ran into the exact same problem. Came with a screwdriver handle and I think around 15 different bits, (torx, Phillips, clutch, flathead, etc...), that inserted into the handle. Pretty cheap to if I recall.
Eric
1967 Base
1969 Base 307 3spd matching #'s X44
1968 C-10 Short Fleetside Custom
dannystarr
« Reply #4 on: September 29, 2015, 08:30:42 PM »
I ordered the one from Amazon. I have SO many bits. I gotta take a look thru them all someday and see, as I might have them. I have MANY security bit tips also. But for now, got a small leak to take care of...D
« Reply #5 on: October 01, 2015, 05:10:24 AM »
I was too slow. Just got a clutch bit with a set today. Don't need it and would have sent it to you....
dannystarr
« Reply #6 on: October 01, 2015, 06:07:43 AM »
I appreciate that Kurt.  8) 8) Save it for another member someday?... D
