If you had power before the battery change, make sure the battery is charged and hooked correctly. Then if that is good to go, I'd look at my ground wire and make sure it is not broken or corroded to the point where you have no contact and check your positive cable as well. But it does sound like a battery or ground issue to me because if there is no ground nothing in the car will work.
