Author Topic: 69 BB zbar angle  (Read 11954 times)
Re: 69 BB zbar angle
« Reply #15 on: September 26, 2015, 08:02:08 PM »
This is showing the rear clip (closest to trans)  it is roughly 3" from the lip of the toe board to floor.
Here you can see it is 4" from the crossmember.
It is roughly 1.5" from the bottom of the floor
This is the middle clilp if your car had it.  It is the same 1.5" from the flat of the firewall / toe board.
It is roughly 11" from the flat of the floor at the same angle of the way the toe board comes down to the perpendicular portion of the floor to the ground.  If that makes sense.
HawkX66
« Reply #16 on: September 26, 2015, 10:17:32 PM »
Great pics. Thanks! I still have that section of my tunnel. I kept my whole tunnel when I cut it out. I just cut it in half to make it easier to move around without cutting my fingers off... Now I know why I never took pics of the clips. Mine didn't have the extra two. Only the one up by the Muncie hole. Thanks a lot for grabbing those pics.
Dave - I hope you don't mind but I removed the previous pics in your reply, since they were also right above this post.  And I didn't think we needed them twice.   :)  Bryon Miller
« Last Edit: September 29, 2015, 05:03:56 PM by bcmiller »
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
