Author Topic: 69 BB zbar angle  (Read 11951 times)
HawkX66
69 BB zbar angle
« on: September 23, 2015, 05:59:23 PM »
What do you guys think of the angle of my zbar? I threw my original 396 in with the original mounts for now so I could see how everything is lining up before I put new motor mounts and my spare 396 in it. Its a 69 BB cross member also. The clutch arm is new GM in the original 621 bell housing. The only thing I'm not absolutely positive of is the tranny mount. It seemed to line up perfectly though. It's a 73 Z28 M21. Thanks.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
BSMIT59
Re: 69 BB zbar angle
« Reply #1 on: September 23, 2015, 06:13:27 PM »
Great Pics Hawk! The angle at the frame mounted bracket does look just a wee bit skewed. Could that bracket be bent just above the top of the frame? The felt washer may make it look more out of whack than it is................ Are those new body mounts?
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
HawkX66
« Reply #2 on: September 23, 2015, 06:23:45 PM »
Thanks Barry. At the frame mount, I think it's just the felt like you mentioned. It does look pretty crazy in that pic though.
They are new body bushings, but original mounts. I repaired the rusted out hole though.
Here's a better pic of the frame mount. Still not a great pic though...:
Dave
Semper Fi!
« Reply #3 on: September 23, 2015, 06:32:09 PM »
Looks good Hawk
HawkX66
« Reply #4 on: September 23, 2015, 06:35:47 PM »
Looks good Hawk
Thanks. So not too much of an angle?
Dave
Semper Fi!
« Reply #5 on: September 23, 2015, 06:41:37 PM »
I have iinstalled many in Chevelles and Camaros, and the angle would have to be off pretty far to bind or be noticeable. Your pics look good. As long as you are clearing your headers and steering box/column, everything should be fine.
« Reply #6 on: September 23, 2015, 07:40:42 PM »
Man that is a nice X-member!  "Its a 69 BB cross member also" I would say you are a bit farther, scratch that, a LOT,LOT farther along than I.
« Reply #7 on: September 23, 2015, 07:54:23 PM »
 Hey now, lets not compare ..... Bentley your car is moving at light speed compared to just a month or so ago..... :D
HawkX66
« Reply #8 on: September 23, 2015, 10:51:47 PM »
Yes, yes it is Bentley ;-) What's going on with yours? It sounded like your new guy was moving like Flash Gordon!
Thanks for that. Good to know. I thought it was ok from ones I've seen and because all the parts were the born with parts from the bellhousing forward, but after having it so far apart, I just didn't quite have the warm and fuzzy with the angle.
Dave
Semper Fi!
« Reply #9 on: September 23, 2015, 11:27:53 PM »
DAVE
1973 Z28 M21?  Does it have a VIN?
My brother is missing the M21 out of his 73 Z28, has the engine, but the trans was missing.
HawkX66
« Reply #10 on: September 23, 2015, 11:33:34 PM »
DAVE
Sure does James. Here it is: 13N194317 I've thought about posting that up a million times, but I kept forgetting.
Dave
Semper Fi!
« Reply #11 on: September 24, 2015, 02:07:04 AM »
"Yes, yes it is Bentley ;-) What's going on with yours? "
Do not intend to hi-jack, so this is all I will say, Waiting to get to underside to see if there are any missing or mis-located items like you had and point out. I know of a few small things needing attn. Single Exhaust Hanger needs to be put on and a small clip in the fuel neck tunnel, jack rod hangar, and some other stuff. Plus a lot of holes for things like antenna, emblems, RS tail light wire holes inside trunk, a lot of seam sealer, etc... need drilled.
A local friend claims I can use his rotisserie, but you know how that goes...it is still in use by someone else. So many loose ends, my head is spinning.
"Hey now, lets not compare ..... Bentley your car is moving at light speed compared to just a month or so ago." -thanks, Austin.
A pic of my tunnel 'cutout' for shifter (before floor repair) I left my tunnel in favor of patch panels. Posted because you had some detail of how you replicated yours, Dave, over on TC.
HawkX66
« Reply #12 on: September 25, 2015, 05:41:24 PM »
Do you have a pic of the pass side of your tunnel? I've looked high and low and I can't find any pic that I've taken of that side of my tunnel. I want to see where the clip goes for the Muncie speedo cable. I know there is one up by the Muncie hole, but I don't remember ever seeing one in the tunnel on mine. I can almost see the area in the pic you posted.
Dave
Semper Fi!
« Reply #13 on: September 25, 2015, 07:32:34 PM »
I can get you pics of the ones on the green car.  I still have it in the air.  Also get you some measurements if that would help.
HawkX66
« Reply #14 on: September 25, 2015, 07:50:59 PM »
That'd be great. Thanks Darrell.
Dave
Semper Fi!
