Author Topic: 1969 camaro SS 350 unrestored - I called the original owner from POP  (Read 17468 times)
abiddle
How much of this is real information vs bad memory, I need some help sorting through. It was great talking to the POP original owner, he had several stories some of which were relevant but all were fun. His father bought the car for him and his brother, they shared it in high school. Racing mustangs on "the bowling alley strip and running from the cops on 42 south" seemed to be his favorite. But our conversation left me with some curiosities, I took these notes.
1. He mentioned a high performance clutch that only held up for 6 weeks. He didn't remember if it was replaced or the new clutch was standard. Its a 4 speed M21, is there any way to figure out if it still has a high perf clutch?
2. He talked about finding oversized bearings on the left side of the engine? He felt like it was important.  ???
3. He said the car absolutely did not have smog equipment on this car. From what I read, all 1969 small blocks had smog equipment. Its the original engine, but the manifolds are unreadable.
4. He also said the GM dash tach was original, so this was a dealer option I guess. Of course that was the first thing I tossed in the trash before we talked.  :'(
5. Steel wheels - red color same as the body. When I bought the car it had silver rallys with the correctly dated. Oddly they have red paint under the silver (I can see red where the silver is chipped) and they are red on the back of the wheel too. I don't see steel wheels as an option for a Norwood car.  The car has been repainted red a few decades ago, would someone actually paint rallys red?
Re: 1969 camaro SS 350 unrestored - I called the original owner from POP
« Reply #1 on: September 21, 2015, 02:37:10 PM »
1) Most likely talking about an aftermarket over the counter part(s). M21 most likely not original to your car as it was not offered with a 350-300hp.
2) He was having a delusional thought from a failed memory. No such thing.
3) ONLY manual Sm. Blocks have smog in 69. If it has a provision for smog tubes, it should have smog. If not, the manifolds are either replaced or the car was originally an auto trans car.
4)Not much can be said or done about that. Need to see a pic to verify.
5)Yes, I have seen painted (different than factory) Ralleys. Steel wheels were not an option, they were what you got if you did not check off an optional wheel like a ralley.
All this info is useless without a picture collection of relevant items, like the trim tag, dash, wheels, POP, Trans code etc..Right now, it is just speculation. How many owners between you and original owner? Any # of owners could have switched/painted parts etc.. and do not rely on geezers (like him or me) to have a faultless memory. Us old guys have been known to embellish things too. Another thing, just 'cause (I assume Father's name) his name is on POP, does not mean he was the original owner, it could have been sold under warranty and a new POP issued with some alterations done prior to his ownership. And 2 brothers shared car? No telling what was changed or done that each would have a different recollection or story. Good luck, welcome to the site and let us learn more about you, your car and how you came about owning it. Thanks.
abiddle
« Reply #2 on: September 21, 2015, 02:59:14 PM »
Thanks ko-lek-ter. A long time ago I decoded this stuff, but my memory is probably as bad as the original owner's memory. The POP was in the glove box when I bought it, it looks like the POP was made to both of the brothers. I'm pretty sure they were the original owners. Pictures of the POP and the trim tag attached.
jdv69z
  • 69 RS Z/28 52E
« Reply #3 on: September 21, 2015, 03:03:00 PM »
It looks to me like there are no smog provisions in the manifolds in the pic, so those are for auto trans.
Jimmy V.
abiddle
« Reply #4 on: September 21, 2015, 03:18:21 PM »
POP reads
T1107HA Tonawanda Nov 07 (1968) 350ci/300HP L48 4 speed
P9R31 4-speed Muncie Model year 9 October 31
from the CRG decode, when I don't have a suffix how do I read this? Why does it say Muncie M2x when no suffix?
   s  = suffix
       PowerGlide and TH350 (not used on all):
          D = day shift
          N = night shift
       1969 Muncie 3-speed
          B = 2.42 first gear ratio
       1969 Muncie 4-speed only:
          A = M20
          B = M21     Use of the Muncie type suffix
          C = M22     began with 21 Oct 68 production.
   Examples:
     R7S21  Saginaw 4-speed, Nov 21, 1966
     P8R01  Muncie M2x 4-speed, Oct 01, 1967
     P9T11B Muncie M21 4-speed, Dec 11, 1968
« Reply #5 on: September 21, 2015, 03:18:56 PM »
The manifolds are for an auto.  You can see in the last pic the raised boss area and bolt hole (or rivet cant remember) in the center port of the manifold for the heat stove pipe that goes up to the air cleaner.
Can you get a better pic of the just the pop plate?  Thanks, Darrell
abiddle
« Reply #6 on: September 21, 2015, 03:42:22 PM »
POP close-up, when I found this in the glove box I had no idea how important it would be.
abiddle
« Reply #7 on: September 21, 2015, 03:54:41 PM »
In the L48 SS package, CRG says the package includes "clutch". Maybe this is "performance clutch" Derl (original owner) was thinking of?
Super Sport Package: incl special engine,
dual exhaust, springs, tires, clutch, radiator,
MC1 transmission (in 69), axle and u-joints,
starting motor, hood, badging, and stripes.
« Reply #8 on: September 21, 2015, 04:57:06 PM »
Well who can fault a guy for loving garnet red? (Even painting the wheels red)
 8)
1968 Z28
« Reply #9 on: September 21, 2015, 05:11:06 PM »
The mention of "Clutch" is due to the L48, manual shift option, being equipped with an 11" clutch as opposed to the 10.4".
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #10 on: September 21, 2015, 05:33:11 PM »
So moving up to the L48 mandated that you got the 11" clutch?
abiddle
« Reply #11 on: September 21, 2015, 06:58:07 PM »
Answering my own question on the muncie code. POP plate stamped P9R31 (4-speed Muncie Model year 9 October 31 with no suffix).
Transmission stamped P9R31A, so this is an M20. Not a very good picture, I don't fit under the car like I used to.  :o
abiddle
« Reply #12 on: September 21, 2015, 07:40:20 PM »
Hi everyone - thanks for the help. This is my camaro, first time out of the garage in 5 years. Took awhile to figure out my issue(s), rebuilt the carb and new coil and replaced the points with pertronix then new gas and plugs etc, and magically it came back to life. Lots of little old wiring/lights issues, I need a rear harness and both parking light wires are "touchy". But if I run around the car and squeeze all the wires just right, all of the lights work at least for a few miles.
Any suggestions where I should buy the rear harness and parking light wires to maintain original appearances?
Thanks - Andy
« Reply #13 on: September 21, 2015, 08:01:50 PM »
Lectric Limited Inc...  https://www.lectriclimited.com/
« Reply #14 on: September 21, 2015, 08:03:57 PM »
Man that is a lot of red....
Red on Red (with red endura bumper) and then someone painted the wheels red at one point, and then the redline tires.
