Author Topic: Wittek Tower Hose clamps  (Read 6153 times)
my69Z28camaro
« on: August 28, 2015, 10:00:20 PM »
What is the best way to install Wittek tower hose clamps on radiator and heater hoses to prevent leaking under pressure?  I have read and seen you tube videos on various methods from holding the tower portion with pliers while tightening the bolt . . . to simply just tighening the bolt.
69 Z28 RS X33 50 A 713 Endura Console Rosewood
Re: Wittek Tower Hose clamps
« Reply #1 on: August 28, 2015, 11:13:26 PM »
Hey, if we are talking the reproduction Wittek then yes try your best with some channel locks holding the tower while it is tightened down.
If we are talking originals, I have had a couple dozen originals that I have used and re-used and never (knock on wood) had any leaks or issues with the tower moving
L78 steve
« Reply #2 on: August 29, 2015, 12:39:02 AM »
A tiny bit of lube on the screw threads and point will help.
69 Z/28 Dover White. SOLD
« Reply #3 on: August 29, 2015, 12:59:29 AM »
A little lube also helps where the base of the tower slides through the ends of the "saddle" - reduces the torque required to tighten the clamp.
dannystarr
« Reply #4 on: August 29, 2015, 01:31:02 AM »
I have removed several dated 2/68 on my car. Putting them back I put a tab of high heat wheel bearing grease on the inner area where the square nut slides up and down. And a little on the threads using an acid brush. Then I take my baby slip joint pliers {channel Locks} and did what the guys said. Held them right in place so they don't torque to the side. 1/4" drive Ratchet, or the proper nut driver and make them up. No leaks  ;D  Danny
my69Z28camaro
« Reply #5 on: August 29, 2015, 04:35:23 PM »
To all of you, thanks for all of the suggestions.  I will try the lube / grease in the various places noted, hold the tower with my channel locks and tighten the bolt with a nut driver.  I will let you know my success in not having a leak.
