Author Topic: 68 Z28 anyone make pre bent stainless lines for the proportioning valve/splitter  (Read 5574 times)
barsteel
Hello -
Getting ready to install the correct booster, MC, and proportioning valve/splitter brackets on my '68 Z28.
Does anyone make pre-bent stainless lines for between the MC and the proportioning valve and splitter block?
I've searched all of the usual suspects (Ricks, Year One, Classic Industries, Ebay), and I can't find any...
thanks...
Chris
Chris, check with Inline Tube...
http://www.inlinetube.com/
barsteel
Dug some more and answered my own question - www.camarocentral.com has them...
RSZ28, thanks for the reply...
Chris
Right Stuff Detailing, Fine Lines if they're still around. Inline Tube has great products, difficult web site to navigate. I've used Camaro Central quite a bit, too -
Hello -
thanks...
Chris
InLine Tube is one of the best suppliers! Chris, if you are only addressing the MC area and not changing any other lines may I suggest reviewing the thought of stainless lines for two reasons. They can be very difficult to work with and it will look like a mismatch compared to other lines. SS lines can also be a bugger to seal. Many times these brake lines need minor changes to fit properly and the steel are both easier to fit up (they can be a rascal too) and have the correct look.
Charley
What he said.....
I would not use stainless.
Kelley W King
I agree, SS is a bugger to seal.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
barsteel
Thanks for the input.  I just ordered the OEM steel lines.
Chris
