Author Topic: best intake for 1968 327/275 hp  (Read 4801 times)
Canada69
« on: August 22, 2015, 03:49:13 AM »
I have a 1968 3914678 HH 327 275hp engine and would like to build it up somewhat. I purchased a pair of 1996 10239906 heads and now need to determine which intake will work the best and if I should change the cam too, I realize that a cam change would involve a fair bit mmore money.
I would like to build this engine on a tight budget(I've spent $550 to date) and hope to achieve 375-400 hp.
Keith
350/400hp turbo 400 57 57 now black with Z28 stripes
Real 69 Z-28 BU 3.73 rear diff dated Dec 14 '68
Real 69 SS350 79 B Sold in 1975
dutch
Re: best intake for 1968 327/275 hp
« Reply #1 on: August 22, 2015, 04:59:00 PM »
Probably a Edelbrock Performer (non RPM version) which is available in both regular and Vortec configurations and allow both a spreadbore or squarebore carb to be mounted up good if you ever change carbs - not much higher than a stock manifold if at all but worth checking hood clearance - dimensions should be readily available on the Edelbrock site I'm sure..
