Author Topic: Update Camaro is making progress once again SS/RS 69 BB  (Read 30144 times)
« on: August 20, 2015, 04:20:48 AM »
I thought I would share a few pics of some work done on  my car. B. There is a bad gap where LH door meets 1/4. Waiting on hinge pins kit to tighten up door. Not sure what the problem is yet as this is not how it was before the 1st guy did the work on this door.
Re: Update Camaro is making progress once again SS/RS 69 BB
« Reply #1 on: August 20, 2015, 04:22:34 AM »
and...
« Reply #2 on: August 20, 2015, 04:30:27 AM »
Door before. Also PBT stamp-someone got creative as T is inverted and B is superimposed over the T ,pic does not show real well. P is over a dimple in firewall. T is to left of P and upside down. Picture the T upside down and along the vertical leg of the T they put the straight edge of the B over it.
« Reply #3 on: August 20, 2015, 11:57:01 AM »
Looking good!!  Glad to see no spoiler!!
« Reply #4 on: August 20, 2015, 12:17:09 PM »
Other than adding VE3 & L78, I am being true to 'how it came'. A true Restoration, not a 'cookie cutter' over embellished, lost it's identity type ride.
« Reply #5 on: August 20, 2015, 12:19:37 PM »
You mean like a clone..   :o    :P
HawkX66
« Reply #6 on: August 20, 2015, 12:24:16 PM »
That's awesome Bentley. I'm happy to see your progress! Are the quarters and/or rockers original or do I remember you saying the quarters were replaced back in the 80s?
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #7 on: August 20, 2015, 05:41:29 PM »
Bentley, we found the hinge pin kits to be nothing like the originals and used a donor. Not a big deal but hated to change the look, hence the donor route.
« Reply #8 on: August 20, 2015, 06:26:56 PM »
Chick, you know I would have preferred the "donor" route myself. And if any one has some good LH hinges PM me.(oops,is that an ad?).
I need them to keep body work progress going. Difficult to find with age of car and known problem area.
Cook DW...clone, hmph!..you'll get yours buddy.....LOL
Hawk, Yes your memory is still sharp, 1/4s put on in '83
« Reply #9 on: August 20, 2015, 06:56:24 PM »
Willie makes his own detent rollers and other parts. http://www.hoodhingerepair.com/ I send 67 hinges to him because they are different from 68 and 69. His procedure is better than factory. He bronze bushes the detent rollers on 67's. For what he charges it is not worth my time to rebuild them. 67-69 OTC kits are not as good as his. Not sure why a shop would proceed with bodywork without doing the hinges first.
« Reply #10 on: August 20, 2015, 07:26:35 PM »
Keep up the progress Bentley! I hope your getting excited, I know the rest of us are looking forward to seeing it complete.
« Reply #11 on: August 20, 2015, 08:09:06 PM »
        not sure why a shop would proceed with bodywork without doing the hinges first.
Scott, You are exactly right. The work is held up till I get the hinges done. They (shop) have worked on other issues in the mean time. They are the ones that told me nothing else can be done till the hinges are fixed.That is why I ordered what I did, only to find out I did it wrong, because I need a solution and pretty quick, these guys move quicker than the last guy because I would have had another 8 mos. to do the hinges had it still been there . I thought the repair kit was my only option short of buying repro hinges. Anyone tht has a decent set of hinges or will exchange, I may have a week to come up with something
« Reply #12 on: August 20, 2015, 08:22:46 PM »
I would contact Willie at http://www.hoodhingerepair.com/
if Sauron recommends him. Sauron sounds like he has had a good experience with the guy.
ban617
« Reply #13 on: August 21, 2015, 12:40:07 AM »
Bentley , as long as the pins & bushings are good that shouldn't hold up the door alignment ... Would it, the detent is to hold the door open correct ?
« Reply #14 on: August 21, 2015, 02:32:00 AM »
I understand your point. I think Chick was wanting to show the quality difference from his pic, not specifically was he talking about the detent, just the hinge pins, but illustrating some inconsistencies. (Thanks, again,chick). My pins and bushings are junk.
I am going down a new path right now of the world of reproduction parts. I am hoping friends on CRG can navigate me in what parts I should buy for accuracy and quality. Up till now, I have only bought or acquired a few non GM parts and I have been very disappointed, to the point, that I avoid repro stuff all together.
But, the time has come that all soft items, from sub-frame mounts to trunk mat to window felts, to vinyl top, etc...you get the point that I will need to buy and I cannot afford NOS when a trunk seal goes for, like, $1200! YIKES! My car is not that desirable that I could justify that kind of outlay for a part. Nor, am I that ,um, crazy to spend that kind of money, although I am about as crazy over 67-9s as you can get.
If these pins I ordered are, like Scott says, inferior and I have a better alternative, this could be costly and problematic. I am the type that likes to do it one time right instead of three times wrong. I get very frustrated.
