Author Topic: The Hugger goes ZL-1....  (Read 183386 times)
Re: The Hugger goes ZL-1....
« Reply #90 on: November 07, 2017, 02:19:02 AM »
pics loaded fine for me, and i am on a slow connection. I like all the pics in general. What kind of heat shield is that for the starter solenoid?
« Reply #91 on: November 07, 2017, 05:21:57 AM »
They wouldn't load at all for me yesterday. They loaded instantly today. Go figure. :)
hgger69
  • Hugger orange rules!
    • Håkans Motorsida
« Reply #92 on: November 07, 2017, 07:38:37 AM »
Thanks!
The heat shield is the one that's in the AIM and was originally mounted on all engines I guess?
Its just a thin metal plate so I'm not sure how efficient it is but I like how the engine designer thought when they made it back in the 60:ies...they knew the solenoid has a place there near the manifold so...
Hakan from Sweden
www.hakansmotorsida.com
hgger69
    • Håkans Motorsida
« Reply #93 on: November 07, 2017, 07:39:07 AM »
Great, Kurt!  ;D
Hakan from Sweden
hgger69
    • Håkans Motorsida
« Reply #94 on: November 08, 2017, 09:43:43 AM »
Going somewhere.....  :P
Hakan from Sweden
hgger69
    • Håkans Motorsida
« Reply #95 on: November 12, 2017, 03:26:48 PM »
A friend of mine, who´s a self taught welder, got a mission to contribute to the history of our ZL-1.
A place for the lambda sond to be in....can be useful in the future! ;)
Hakan from Sweden
« Reply #96 on: November 12, 2017, 09:39:52 PM »
is that a bung for a fuel air mixture gauge?
 Also are you going to put a 4 speed manual or more modern 6 speed manual in it with a stick looking hurst shifter by chance?
hgger69
    • Håkans Motorsida
« Reply #97 on: November 12, 2017, 09:49:14 PM »
Yes! I thought its was called lambda probe in english..?
No! Going to run it with the old TH350 I had before....low stall speed and shift kit.
Hakan from Sweden
« Reply #98 on: November 16, 2017, 04:17:25 AM »
Hakan,
One good looking ZL-1 for sure. Out of curiousity, why the TH350 instead of a TH400 ? I have a bad mental picture of twisted output shafts and exploding internals after that kind of power metering through it. True, a 350 will hold up to mannerful driving, but wasn't really intended for this kind of duty. Just asking -
hgger69
    • Håkans Motorsida
« Reply #99 on: November 16, 2017, 07:20:34 PM »
Hakan,
Thanks, Steve, appreciate it!  8)
I want to keep the TH350 thats already in the car for several reasons...!
One is money, cause building a ZL-1 isn't cheap anywhere...second I'm not gonna race this car and use sticky rubber so hopefully the 350 should manage with me driving it?!
But you have a point and we have thought about it but for now this is how gonna start!  :-\
Hakan from Sweden
Kelley W King
« Reply #100 on: November 16, 2017, 09:31:18 PM »
Without big tires I think the 350 will do OK. Might want to think about that low rpm converter unless your motor likes to idle at 6 or 700 rpm.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
hgger69
    • Håkans Motorsida
« Reply #101 on: November 16, 2017, 09:38:37 PM »
I think you're spot on there, Kelley!
There are a lot of things that we probably have to deal when it comes to getin the ZL-1 back in the car again... ;)
Hakan from Sweden
« Reply #102 on: November 17, 2017, 05:24:10 AM »
I would recommend saving the turbo 350 and your old motor for another vehicle.
To bad you aren't closer I have a 454 and turbo 400 that got built with a street/strip idea, (10 seconds in the 1/4 on all motor) and then never got installed. I am trying to find a buyer for both...and the search continues.... ::) :P
hgger69
    • Håkans Motorsida
« Reply #103 on: November 17, 2017, 07:58:32 AM »
Old motor long gone...it´s in a 68 RS now!  ::)
I´ll try the TH350 first and then wait ´n see...  :P
Hakan from Sweden
hgger69
    • Håkans Motorsida
« Reply #104 on: November 28, 2017, 01:05:29 PM »
Destination reached! I think the ZL-1 is starting to purr just being in this situation....!  ;D
..and yes, it´s a famous Vega built in US long time ago but that´s a completely different story! ;)
Hakan from Sweden
