During wintertime it´s a lot of other things do to with the family so I have to sneak out in the garage for my quality time...
Due to the failure of my old distributor I had to order new parts from US & A and they finally arrived the other day. My choice was a HEI from PerTronix and their FlameThower model D71000 with the latest HEI III module and adjustable rev limiter. Got a set of matching cables from Taylor mad to go over the valve covers:
Also got the ugly green gaslinkage return spring:
While my combo of a ZL-1 and a TH350 not are the most common thing to do my old bracket for the kick down cable didn't fit....
I couldn't find anyone to buy so I decided to do my own! With some old school paper work I got myself a good looking prototype.
Ludde TMW, The Magic Welder, my pal made one ZL-1 inspired from aluminum.
Did a test fit together with the ugly green thing and it turned out ok, I guess!
..after some adjustment and a sand blast it turned out like this:
Before mounting the HEI I changed the internal springs to most correct ones for my application and set the rev limiter to 7500 rpm!
Then I realized that I hadn't test mounted this very masculine distributor in the Camaro, oops...will it fit between the air filter and firewall...?
It did!
...and now I realize that maybe the engineers at Chevrolet already planned for a HEI when they made this cowl air cleaner or is just the OEM:s that are done this way?
With the knowledge the the HEI would fit I adjusted the oil pump gears and found a still position for the HEI, mounted the cables and voilá.
Sure, it's a lot of lack of space but hopefully it will work.
The radiator has gotten som fresh paint and been mounted in place together with the new fan shroud:
Talking about the shroud you can se how bad it fitted at the top as a "bolt-on"...but after some adjustment I think it will work great!
Also mounted the correct upper hose together with the correct, and quite useless, clamps.
That´s all for the moment, folks!
