Author Topic: 1967 Tranmission cross member orientation  (Read 4560 times)
67rs327
« on: August 02, 2015, 02:26:14 AM »
So in my haste to remove the transmission cross member from my '67 (4 speed) - I failed to notice which side is forward (or aft?)
There's a single hole in the center section near the 2 main mounting holes - and also 2 smaller ones on one  side and a single directly across from those on the other side. Curious what these are for and what direction should the cross member be in for reinstallation? Thanks.
1967rs L30/M20 Bolero Red - LOS 11A.
Chris - New Hampshire.
1968 Z28
Re: 1967 Tranmission cross member orientation
« Reply #1 on: August 02, 2015, 02:49:00 AM »
The three small holes are for the shifter mounting bracket......therefore the crossmember would mount with them on the driver side.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
67rs327
« Reply #2 on: August 02, 2015, 02:55:30 AM »
Thanks man. Knew someone had a quick answer to that.
