Author Topic: No Power to the Gauge Fuse  (Read 5160 times)
mikecio1
« on: August 01, 2015, 10:05:42 PM »
I just did some work under the hood and when I hooked everything back up I had no power to the Horn, Fuel Gauge and the Acc that I use for my after market radio. The first thing I checked was the fuse. When I found there is no power to the fuse marked "Gauges". I tried to track it down with no luck. Can anybody give me any suggestions on where under the hood I should be looking. Let me make note that the original charging system had been converted to a single wire system a long time ago, and there is an HEI ignition. There was never any issues in the past. I am afraid that I may have messed with a wire unintentionally.
69pace
    • TeamCamaro - Moderator
Re: No Power to the Gauge Fuse
« Reply #1 on: August 01, 2015, 11:55:01 PM »
Mike I posted a reply over at TC to look at.
mikecio1
« Reply #2 on: August 02, 2015, 12:49:50 PM »
Thank you!
69pace
« Reply #3 on: August 02, 2015, 02:38:27 PM »
no problem, and I posted this morning a few wiring diagrams to help you troubleshoot your issue.
mikecio1
« Reply #4 on: August 02, 2015, 09:13:55 PM »
Excellent!  :D
