« Reply #30 on: August 03, 2015, 06:36:58 PM »
All of you have referred to a galvanized finish on the tank. I, too, referred Camaro tanks as galvanized and thought it was so until I took my tank to a radiator shop I use frequently for repairs. The owner, whose opinion I truly respect and value, because he has done many world class restorations (Pebble Beach stuff). He told me the tanks were not galvanized, but rather have a tin / lead dipped finish. This proved true, because off the car, the tank is moved around working on it and small scratches appeared quite quickly, because of the soft (lead) coating. I was told to clean it up with a piece of very fine steel wool (which worked, but go lightly as the coating is very thin). Do not breathe in the lead dust! I only felt this was noteworthy, because we are into the facts about these cars, right?
The raw coil stock the tank was stamped from was "terne-coated" with that lead/tin alloy as a secondary operation after the steel rolling mill, prior to stamping the tank halves. Some folks think the tank is galvanized steel, but it's not.
Excellent points.. Learned something new today.
Ditto. Thanks guys.
Logged
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
