Any update ?
I've been struggling with a number of 7029202 issues for the last couple of weeks - what I deserve for relying on someone else's rebuild (read as mangle).
Your power valve may not have been positioned well during the "top drop". Tough to keep it from popping up out of the bore unless you are very careful, or use a new split bushing which will help keep the thing positioned correctly until the top casting is set in place. It only takes four or five hands to do it, as you probably know. There is also a small spreader spring that should be in place on the upper needle mount area, helps keep them aligned and not touching the float arms. Gasket will position the hanger correctly if the power valve/needle assembly is installed in the gasket correctly -
Secondary well plugs can be replaced with new o-ringed plugs. I'm doing that on mine next weekend, will share some pics on procedure if you'd like them.
My worst problem is a heli-coiled inlet. Someone butchered the gasket sealing surface around the inlet fitting at the same time - my worst headache now. Hopefully I can get it sealed.
I still think they are great carbs, despite some drawbacks in design (like the front bolts), they flow well and last a long time in use with minimal care. A lot of parts are available still, so good luck with your 202 -
