Author Topic: Tachometer Wiring  (Read 17944 times)
Axlman
  • 1967 RS SS Convertible
Tachometer Wiring
« on: July 20, 2015, 06:53:13 PM »
Hello all.
Anyone have a wiring diagram of advice on how to wire the 1967 Tachometer to make it work with a MSD ignition?
I was running FAST EFI so the Tach sent to there on the handheld.
Now I have removed the EFI and want to wire the original tach properly and am lost.
I have a yellow and white wire, a brown wire, and the grey wire on the MSD which is the sending unit. But I am not sure how they relate, or what to send or wire up to the gauge or cluster.
1967 Camaro RS SS Convertible
miket1
Re: Tachometer Wiring
« Reply #1 on: July 21, 2015, 12:15:09 AM »
The Gray wire is the Tachometer on MSD Ignition Box,  I run two of them
69 Z28 Burgandy
Axlman
« Reply #2 on: July 21, 2015, 02:40:16 AM »
The grey  wire off of the MSD is the tach sending wire.
But what does it connect to and where do the other wires in the wiring harness connect?
« Reply #3 on: July 21, 2015, 12:12:51 PM »
Which MSD box do you have?  Part #?
Axlman
« Reply #4 on: July 21, 2015, 06:29:13 PM »
MSD Ignition Digital 6A
PN6201
« Reply #5 on: July 22, 2015, 01:06:32 AM »
Is this what you are wanting??  If this isnt how yours is then I would contact MSD..  Im not sure I have seen a yellow and brown wire on a 6201 before..
Axlman
« Reply #6 on: July 22, 2015, 01:41:18 AM »
Hello guys.
I am likely confusing everyone about what I am trying to find out.
The MSD was wired before and reported the rpm's to the FAST EFI module hand held.
Now that the FAST is removed from the car I have the old wires (not used before) from the wiring harness that are white and yellow and brown I believe. They are not going anywhere and sit by the wiper motor.
And of course the MSD does have a grey wre which is a sending wire.
How to wire them all together to make the original Tachometer work now is what I am after advice on.
Hopefully that better explains my dilemma:)
Axlman
« Reply #7 on: July 26, 2015, 06:48:12 PM »
Hello.
I posted last week but haven't received anything that shows exactly where the two wires are supposed to go.
One Brown and the other Yellow and White.
Does anyone know or have a picture of them on the 67?
No idea where to connect them.
Axlman
« Reply #8 on: July 26, 2015, 08:49:16 PM »
To better explain, the two wires are located by the wiper motor and open there.
They have two small prong connectors that look like a u shape.
1968 Z28
« Reply #9 on: July 26, 2015, 09:14:54 PM »
I presume the wires you are referring to are in the stock wiring harness......right?  If so (according to the wiring diagram) the brown wire is the Tach wire that would attach to the (-) negative terminal on the coil and the other wire should be the white/orange/purple that would attach to the (+) positive terminal on the coil and the yellow wire would also be attached to the (+) positive terminal on the coil.  These wires would have been disconnected upon installation of the 6A and the new wires from the 6A would have been connected to the coil, distributor, and tach as follows.....
     Orange wire to the (+) positive terminal on the coil
     Small Black wire to the (-) negative terminal on the coil
     White wire connected to the original distributor wire
     Gray wire connected to the original brown tach wire
     Smaller Red wire to the ignition key
     Large Red wire to the (+) on battery
     Large Black wire to the (-) on battery
Those wires that were removed and not re-used at the original wiring harness should have been taped, folded back and tied down to the original harness.
Hope this is what you are looking for.
BTW.....here is a link for the MSD installation instructions......http://www.americanmuscle.com/msd-6a-digital-ignition-7995-install.html
« Last Edit: July 26, 2015, 09:56:13 PM by 1968 Z28 »
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
1968 Z28
« Reply #10 on: July 27, 2015, 03:55:51 AM »
One minor correction to the link I listed above.  The web page I linked to above had another link to a PDF file for the MSD installation....well I inserted the link to the web page instead of the link to the PDF file.
So here is the correct link for the official MSD 6A installation instructions.......http://1.cdn.lib.americanmuscle.com/files/14221-14222.pdf
Jerry G.
1968 Z28
« Reply #11 on: August 03, 2015, 04:52:20 PM »
Axlman....has your question been answered satisfactorily?  If not, let us know.
Jerry G.
Axlman
« Reply #12 on: August 04, 2015, 03:25:53 AM »
Hi Jerry.
Thanks for the posts and information. I have the car at Pro-Stock getting some items addressed so I haven't had a chance to try the wiring.
I may have it back tomorrow or Wednesday with any luck.
I will post as soon as I can try:)
69RSZEE28
« Reply #13 on: February 06, 2020, 01:26:40 AM »
I want to hook up my repro/stock tach in my '69 which has never been hooked up because I had an Autometer in the car that's gone now. I have a MSD 6AL ignition box, MSD distributor and MSD coil in the car. I don't want to fry anything so I need some clarity how to get it working properly. Am I using the stock wiring from the harness (fork connector with 2 wires, another fork connector with one wire) that hang by the wiper motor to connect to coil? There is talk about some filter for the tach, is there a filter in this tach? YES or no? MSD says connect gray wire from ign box to somewhere which I don't know where! So what I need to know is: am I simply hooking up stock wires to coil from harness to make it work? IF that doesn't work am I using the gray wire from the MSD box to get the tach to work and where does that wire go, and what about this "tach filter? MSD's instruction booklet for the 6AL box says "bypass in-line filter. Thank you for any help
