Author Topic: AAW 69 Engine harness differences  (Read 14577 times)
Re: AAW 69 Engine harness differences
« Reply #15 on: August 04, 2015, 03:23:56 PM »
The bracket which bolts to the bell housing is coated on the original and is bare on the repro, are they using black harness clips again or are they still white?
BillOhio
    • photobucket
« Reply #16 on: August 05, 2015, 12:34:54 PM »
Is the coating a paint? One they sent was cad plated. I just got the harness to my starter, header had worked on it a bit.
1968 RS 327 4 speed
« Reply #17 on: August 05, 2015, 12:52:53 PM »
Its coated to keep from cutting the wires..  MY original harness on the 67 & both 8's are the same as what James posted above.
BillOhio
    • photobucket
« Reply #18 on: August 05, 2015, 02:27:20 PM »
Ok yeah the new one wasn't.  I thought I might swap mine
1968 RS 327 4 speed
« Reply #19 on: August 05, 2015, 02:54:03 PM »
No not paint like plasti dip.
« Reply #20 on: August 21, 2015, 01:46:41 PM »
The wiper motor wiring as mine came exactly like the original. I used my original to make up a test set up. I need to check that bell housing bracket (pretty sure I used the original)! Thanks James!
BillOhio
    • photobucket
« Reply #21 on: August 21, 2015, 01:57:23 PM »
Wonder why the 69 is different when chick's has the same colored wire and connector as mine? Shaking my head!
1968 RS 327 4 speed
69pace
    • TeamCamaro - Moderator
« Reply #22 on: August 21, 2015, 03:27:01 PM »
The plastic can be changed out easily if the brown bothers you or you can remove it, paint it and then reinsert the leads. ;)
I'll have to look at my jumper wire, thought it was blue.
BillOhio
    • photobucket
« Reply #23 on: August 21, 2015, 06:11:45 PM »
Guy I talked to acted like mine was made wrong. I was like well it needs fixed!
1968 RS 327 4 speed
