Author Topic: 1969 - June to End of Year 10-bolt Axle stamps  (Read 14052 times)
« on: July 10, 2015, 06:36:14 PM »
We have had another thread going looking at the stampings on 1969 axles that used the two different casting numbers late in the year.  This topic is related, but takes a wider look, and is also looking for information from 10 bolt axles which are more common.
If you would like to participate, you can post the following please.
1.  Casting number on the center section.
2.  Casting date on the center section (in the "webbing" area).
3.  Data stamped on the front part of the passenger side axle tube.  Picture requested please.
Make sure your car (or the axle) was assembled between May of 1969 and the end of the model year.
You can either post it here, so send me a PM.  If you send a PM, your photos will be kept confidential.
Thanks in advance.
« Last Edit: July 15, 2015, 06:54:13 AM by KurtS »
Re: 1969 - June to End of Year 10-bolt Axle stamps
« Reply #1 on: December 06, 2015, 10:22:18 PM »
BUMP.....where are the 10 bolt guys???
« Reply #2 on: December 06, 2015, 10:37:50 PM »
I think I still have the diff from the 10E X11 car..  Ill look when I have time.
« Reply #3 on: December 06, 2015, 11:06:48 PM »
...??.. maybe out looking for a 12-bolt...??  :)
« Reply #4 on: December 07, 2015, 04:16:26 AM »
I am sure they are looking or found a 12 bolt and tossed the 10.... ;)
« Reply #5 on: December 12, 2015, 05:11:59 PM »
Darrell, did you have a chance to check out that 10 bolt?
Anybody else?
« Reply #6 on: December 12, 2015, 05:35:12 PM »
No sorry..  I plan on getting out this weekend.  Hopefully Ill get over there and get the info.
« Reply #7 on: December 15, 2015, 01:42:10 AM »
Ok here goes...
1.  3968340 NF
2.  Not legible
3.  CBP 1010 G1
Car is a 10E of 69 X11
« Reply #8 on: January 31, 2016, 10:39:59 PM »
Thank you Darrell.
Interesting to note the same format as 12 bolts, as expected. C BP with a space between.
« Last Edit: March 04, 2016, 04:28:39 PM by bcmiller »
« Reply #9 on: April 23, 2019, 02:49:26 AM »
Another C BP ten bolt axle...
