Author Topic: 69 BB Power steering bracket hardware  (Read 6632 times)
RS_COPO_Canuck
« on: July 06, 2015, 05:16:13 PM »
Hi All - Been straightening a few things out on my car and have a question on the p/s bracket hardware. On the attached UPC N40 A5 - It shows item 2 as part number 3754153 "SPL Washer". At first I thought this would be a split washer.....but looking at item 10 - part number 3792381 - it shows this as a "SPL Washer" as well - and we know that is a spacer. Does SPL mean special? Can anyone tell me what 3754153 is - and if it is a spacer - what thickness?
Thanks in advance!
Re: 69 BB Power steering bracket hardware
« Reply #1 on: July 06, 2015, 07:49:36 PM »
Boston14
« Reply #2 on: July 07, 2015, 02:07:39 AM »
AMK # B-11278   $3.00  for  8 washers.
boston14
1969 SS/RS 350 Convertible
RS_COPO_Canuck
« Reply #3 on: July 07, 2015, 01:22:54 PM »
Thanks guys. I did google up the part # after I posted and saw that ebay auction. Also an old NCRS post came up with those very dimensions. So - it is basically a thick washer.....I probably have a bunch......somewhere...
RS_COPO_Canuck
« Reply #4 on: July 09, 2015, 12:43:37 PM »
While we are in the vicinity of the brackets......how do I identify if the actual p/s pump is the correct one? I heard it is a unique pump. It does have the correct pulley.....beyond that....is there a way to tell on the housing? Thanks again.
m22mike
RS_COPO_Canuck
« Reply #6 on: July 09, 2015, 03:45:18 PM »
Thank you Mr. M22! Mine looks right.
m22mike
« Reply #7 on: July 09, 2015, 06:58:45 PM »
FYI info. I failed to mention in my reply that HBC's web sight is full of good references like AIM sections and pg #'s. Also allot of pn# info as well. I use it often jsut like the ? on the PS pump, good photos. They have the right click disabled, but you can link the web address.
NoYenko
« Reply #8 on: July 16, 2015, 01:37:44 AM »
I went round & round trying to find the correct reservoir for my BB. I bought that same part from HBC and it did not fit correctly, the supply hose was pointed to close to the exhaust manifold. Here is a picture of my original on the right. George
« Reply #9 on: July 16, 2015, 02:32:02 AM »
That left part looks like one off of a Caddy (angle-wise).
