Author Topic: Saginaw speedo gear  (Read 3510 times)
jimbo67rag
Saginaw speedo gear
« on: June 30, 2015, 02:38:46 AM »
My 67 ragtop was originally a 327 3 speed Standard but the previous owner installed a 1973 to. 1975 Saginaw 4 speed. However the speedometer does not work on the car. I removed the speedo cable from the tranny and the little plastic gear is missing from the end of the speedometer cable. Does any one by chance have a part number and or pics of this item. My main case number is 3925656 and the ext. housing number is 326558. I believe this to be a sag from 73/74. I am live in Canada and would like to pick up the gear so I can get the speedo working. Also is there a clip that holds this in the tranny or does it just slide in on the end of the cable. Thank you. Any help would be appreciated.
Re: Saginaw speedo gear
« Reply #1 on: July 04, 2015, 02:52:22 PM »
You can't select the speedo DRIVEN gear you need without knowing the rear axle ratio and tire diameter.
