Author Topic: 8N47515x - Z28 engine  (Read 6534 times)
« on: June 29, 2015, 05:58:39 PM »
Your 302cid/290hp Z28 engine is on eBay...
Engine pad is stamped: 18N47515?  V0711MO  (? = possibly 0)
Block casting number: 3914678
Block casting date: G 6 8
Seller id: cranesperformance
Seller location: Ocala, FL
Seller contact information: 352-216-2273
http://www.ebay.com/itm/231607333217?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: 8N47515x - Z28 engine
« Reply #1 on: June 30, 2015, 12:03:51 AM »
6/29/15: "This listing was ended by the seller because there was an error in the listing."
« Reply #2 on: July 01, 2015, 06:25:53 AM »
Paul,
I think it was 124378N475159, btw. :)
Edgemontvillage
Re: 18N47515 V011MO - Z28 engine
« Reply #3 on: April 08, 2018, 02:58:31 PM »
Block was purchased by my shop partner for his 68 Z (not its original engine), manafuxing revealed a main web crack. The block is repairable. Below is a photo of the stamp:
« Reply #4 on: April 08, 2018, 04:53:13 PM »
Usually they put blocks in a forge and then weld with nickel rod.
How are they going to repair this one?
Edgemontvillage
« Reply #5 on: April 09, 2018, 12:38:40 AM »
No near term plans to repair the block.  It will be shelved in hopes of hearing from the owner of the original, matching chassis 68 Z.
