Author Topic: 69 build sheet info  (Read 3516 times)
Danzo
69 build sheet info
« on: June 27, 2015, 01:04:21 AM »
Looking for info from the following boxes on a 69 396-325 Turbo 400 non a/c car. Box 176 carb FF, box 182 choke thermo CY, box 183 vac fitting H, box 188 gen WB, box 190 p/strg TR, box 208 speedo gear KY, box 213 w/pump DU, box 217 c/shaft AD. If there is a website out there let me know and I will do the leg work. Thanks in advance.
Re: 69 build sheet info
« Reply #1 on: June 27, 2015, 05:02:07 PM »
The codes are shorthand for the part #.
FF - carb code = http://www.camaros.org/carb.shtml#usage
H - tells how many connections to have on fitting
WB / TR - which belt
KY = 3.07
Pulleys - http://www.camaros.org/engine.shtml#PulleySpreadsheet
Danzo
« Reply #2 on: June 28, 2015, 02:34:15 AM »
As always, thank you Kurt.
