Author Topic: 69 camaro steering wheel clean up  (Read 3243 times)
69ZX77MP
« on: June 19, 2015, 01:12:26 AM »
I just bought a original steering wheel .looking at the front,the coloring looks darker than the underside is there something I can do to the front to bring out the original color, with out damaging the wheel thanks
1969 Z28 X77 Lemans Blue 03D
69pace
    • TeamCamaro - Moderator
Re: 69 camaro steering wheel clean up
« Reply #1 on: July 02, 2015, 02:44:02 AM »
I assume you are talking about a colored wheel and not standard Black? Depends on if its grime, or UV radiation fade. Grime can be detailed off with mild soap and a tooth brush and a lot of time. Color fade and not be reversed, you can dye the wheel.
