Author Topic: U17 Wiring  (Read 3649 times)
Mr 396
U17 Wiring
« on: June 06, 2015, 10:30:21 PM »
On the U17 console, I know that the oil line runs under the carpet, question, does the wiring harness from the dash harness also run under the carpet?
1968 Z28
Re: U17 Wiring
« Reply #1 on: June 07, 2015, 12:48:51 AM »
This post from TC shows the routing under the carpet.......http://www.camaros.net/forums/showpost.php?p=2959065&postcount=921.  This is how the wiring on my original 07C is also routed.
The console harness comes down from the main harness, above the accelerator pedal, and bends to the right and goes under the carpet as then shown in the photo in the link above.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Re: U17 Wiring
« Reply #2 on: June 07, 2015, 09:24:48 AM »
As far as I've been able to determine, 68's went under and 69's over the carpet.
Mr 396
Re: U17 Wiring
« Reply #3 on: June 07, 2015, 01:06:33 PM »
Mine is a 68 and have seen it both ways. Not sure which was correct.
Re: U17 Wiring
« Reply #4 on: June 07, 2015, 03:54:54 PM »
Maybe Tim but it might have also been different from console gages or just console. Friends 68Z with console gages goes in on top but the carpet was cut.
