Author Topic: 69 Headlight washer system T-Valves  (Read 35585 times)
Oaklyss
Re: 69 Headlight washer system T-Valves
« Reply #15 on: December 03, 2006, 09:35:08 PM »
If someone would like to sell these fittings, please let me know.
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built-SOLD
1968 GTCS mint unrestored original paint
1972 AMX 401 4 speed, cowl induction, twin-grip, A/C, unrestored, original paint
1963 Oldsmobile Jetfire factory Turbo and Methanol injection, 4 speed, posi, 1 of 4 known to exist
camaro cat
« Reply #16 on: December 04, 2006, 03:45:33 AM »
My car has white an is an 02D Nor.
Loren
1967 RS L30 10C LOS
1969 SS/RS L78 02D NOR
Dave69x33
« Reply #17 on: December 05, 2006, 02:38:00 AM »
Thanks Camaro Cat and Mark x22.  It appears so far that early Camaros (built in Jan and Feb) had white check valves T-fittings.  The only check valves I have seen on original cars have been black valves on 69 Pace Cars built in March and April.  It will be interesting to see what other input other may have on this.
Oaklyss
« Reply #18 on: December 12, 2006, 01:19:02 AM »
The Ys I can recast. I have 3 available now, Dave asked for 2, but I dont have any idea what to charge. I was going to throw them into the restored wiper motors. If someone wants to make an offer, just le me know.
Kevin, got my Y today, great job! Now for the check valve tees...
Camaro Billy
    • 1969 RS/SS
« Reply #19 on: December 21, 2006, 06:19:40 PM »
Here is a photo of the white check valve from a survivor car that won an Vintage award at the Camaro Nat'ls in Carlisle this year.
It is a 04C build.Can't say for sure if it is orig., but it is one of the most complete survivor cars I've seen.
Billy
1969 RS/SS 350/300 Rallye Green . Black Vinyl Top
Dave69x33
« Reply #20 on: December 23, 2006, 01:09:25 PM »
Thanks for the pic Camaro Billy.  Survivors are great to see, photo document, and capture the assemblies build date to judge our cars against!
Does anyone have any GM service bulletin documentation or a GM service part book that calls out the part numbers and/or revision changes on the CE1 head light washer system components?  This may help to date changes to the system components and the white vs. black T-check valves.  Who was the supplier?  Was there more that one supplier?
In the 69 AIM, on page 26 it notes that non-RS Camaros used motor/pump assembly P/N-5045572.  On page 238 under CE1 the motor/pump assy P/N-5045605 is called out for CE1 optioned cars which included the solenoid pump.  Below is a pic I took of the solenoid on a survivor 69 Pace Car with build date 03C. It has the following ink stamped info on the bracket:  “120C   968   TAH 3081210-4”.  I must assume the “3” because it is hard to read.  I would like to decipher these numbers.
