Author Topic: 69 Z28 Fuel line  (Read 12839 times)
L78 steve
69 Z28 Fuel line
« on: May 29, 2015, 05:51:02 PM »
Is the metal fuel line continuous from tank rubber hose to pump? Or is there a break with a rubber hose behind the RH front wheel- body to frame rail transition then back to metal to the pump?
« Last Edit: May 29, 2015, 07:04:26 PM by L78 steve »
69 Z/28 Dover White. SOLD
m22mike
Re: 69 Z28 Fuel line
« Reply #1 on: May 29, 2015, 06:00:26 PM »
OEM was Continues one piece.
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: May 29, 2015, 06:31:44 PM »
My Z has a rubber line between metal line from the tank, and the fuel pump. With the metal line bolted to the sub frame, seems to me there has to be some flexibility between it and the engine to allow for engine movement.
Jimmy V.
L78 steve
« Reply #3 on: May 29, 2015, 07:09:06 PM »
This is like mine and others I've seen but Inline Tube shows it as one piece. I wonder if that is how they make it with the intention of it being cut by the installer.
Would make sense for a 2 piece due to the body to frame movement.
« Reply #4 on: May 29, 2015, 07:14:16 PM »
That's the way they were supposed to be...   that rubber line provides the flexibility from frame to engine.  Check out the AIM UPC 6 pg C6.
PS.  Inline tube also sells the rubber hose and clamps to attach both ends of the fixed hardline (from frame rail to pump and from frame rail to gas tank)...   http://inlinetube.com/rubber%20fuel%20hose/FHS-301.htm
« Reply #5 on: May 29, 2015, 07:23:05 PM »
The rubber line in the front is to provide for slight engine movement relative to the subframe.
« Reply #6 on: June 03, 2015, 09:47:33 AM »
The front and rear rubber fuel hose are shown best in the 1969 Camaro AIM UPC 8 page B1 (front and rear hoses).
Fuel line diagrams are also in  UPC 8 page B2 (fuel line - front half) - and UPC 8 page B3 (fuel line - rear half).
rsr
« Reply #7 on: June 04, 2015, 12:39:38 AM »
 F-body Nova used a two piece fuel line.....
L78 steve
« Reply #8 on: June 04, 2015, 01:49:35 AM »
This shows a rubber line at the meter assembly and fuel pump only. So fuel line is one piece.
« Reply #9 on: June 04, 2015, 02:42:59 AM »
In a word...Yes. 1 piece line from after sender line, at RH. rear frame rail, joined by rubber line, to fuel pump rubber line.
L78 steve
« Reply #10 on: June 04, 2015, 11:08:33 PM »
Got it, Thanks.
« Reply #11 on: June 09, 2015, 07:33:33 PM »
I will add, (not sure if it is recommended), but where the rubber line attaches to go to the pump, is where I install my Fram clear fuel filter. It seemed like a good idea since it is tucked out of the way, and hasn't prevented the car from running any differently.
L78 steve
« Reply #12 on: June 10, 2015, 01:26:56 AM »
I have the clear filter at the line cut behind the RH front wheel.
« Reply #13 on: June 10, 2015, 06:08:38 AM »
Looks like we think alike ... 8)
Scary... ;D
