Poll
Does your 1969 Z28 Camaro have the RS option too, from the factory?
Original Z28 non RS
38 (56.7%)
Original RS/Z28
28 (41.8%)
Original Z28 but RS option added later
1 (1.5%)
Total Members Voted: 65
Author Topic: 1969 Z28 Camaro owners - does your car have the RS option too?  (Read 33530 times)
HOT3O2
Re: 1969 Z28 Camaro owners - does your car have the RS option too?
« Reply #15 on: May 25, 2015, 03:27:00 PM »
I took a quick look at the 69 Z's on e-bay.  From what I saw there were 10 regular Z's and 1 RS for sale. This isn't scientific and can't say 100% there all original. But then again were all just speculating here anyway.
Rick
69 RS/Z28
« Reply #16 on: May 25, 2015, 07:21:56 PM »
Bill posted this hightlighted line below in the other thread that is going on this topic.
The CRG db has just over 1400 Z/28s; 18.55% are also RS.
The is a decent size sample.  Not speculation.    :)
I doubt there are many people that have seen that many Z28s in a lifetiime.
« Reply #17 on: May 25, 2015, 08:53:05 PM »
Bryon, have two close friends that have non RS orig. z/28's. Since they do not spend time normally on this site and if I ask them can I vote for their cars with my votes? Or is it just for member owned cars?
« Reply #18 on: May 26, 2015, 02:53:32 AM »
Chick as long as they are 69s I think that is fine.
6667ss138
« Reply #19 on: May 26, 2015, 05:02:18 AM »
I have two local friends and my Brother that have 6 "real deal" 69 Z's between them. Two are factory RS Z/28's and the other four are not. One of the RS Z's is a Daytona Yellow with yellow houndstooth deluxe interior (POP, numbers car that has been in the area since new) and the other is an Azure Turquoise with white houndstooth deluxe interior, JM certified.
I have already added my non RS Z car to the poll.
« Reply #20 on: May 26, 2015, 05:30:41 AM »
Len, are any of those two friends or your brother members on the site?  It would help if at least one was.  You can put in up to 5,  but since you already voted once, that would limit you to 4 more.  One way or the other we will get it figured out.
6667ss138
« Reply #21 on: May 26, 2015, 06:05:16 AM »
Bryon, no, unfortunately they are not members. I've know the guys and their cars for many years and know the cars are validated. I thought I would just mention them in case you wanted to include them. If not I understand. I don't want to confuse things.
« Reply #22 on: May 26, 2015, 01:08:30 PM »
How about we keep those as a side note, and after a few more weeks we will look at the numbers then?  At that point, we will add those into the totals.
« Reply #23 on: March 02, 2016, 06:54:28 AM »
There haven't been any posts for a while but the latest results were 23 1969 Z28s without the RS option and 17 with the RS option.  :)
X33RS
« Reply #24 on: March 02, 2016, 12:29:23 PM »
Wow, that's close to even.   I'm glad this popped back up, I lost track of it.  I went back and re-read the posts.  One of your posts Bryon caught my attention.   I'm surprised that out of 20,302 Z28's produced in just 69 alone that you only have 1400 in the registry.  I would have guessed that number to be much higher.
I also have been wondering, could it be that possibly RS cars are more likely to be saved by collectors as to the reason why we have almost an even number split in the polls between RS and non RS?  That might skew the numbers a bit.
dale_z28
« Reply #25 on: March 02, 2016, 12:59:19 PM »
I hadn't seen this poll until now, so I voted... I previously owned another Z28 (non-RS) so maybe it should be counted, as well?
'69 X33 02D   Since 11-29-'77
~Ben Franklin
« Reply #26 on: March 02, 2016, 01:09:09 PM »
I would say YES it would be OK to vote again in your case.
Thanks!
Hans L
« Reply #27 on: March 02, 2016, 04:22:06 PM »
Missed this poll the first time around so just "voted" and added my Z/28 w/RS equipment, factory installed to the tally.   Documented on the  chassis broadcast copy as RS equipped.
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
« Reply #28 on: March 02, 2016, 05:58:47 PM »
Thanks!
Oops! Byron, I just assumed that was OK when I originally voted back in May 2015.
dale_z28
« Reply #29 on: March 02, 2016, 06:37:46 PM »
Thanks!
I wasn't able to cast another "vote", maybe because it's one vote per member (or login). No biggie
~Ben Franklin
