Author Topic: '69 Camaro Rear Seat  (Read 4025 times)
my69Z28camaro
« on: May 19, 2015, 06:48:06 PM »
Is the '69 Camaro Coupe rear seat, both bottom and back, narrower with the Deluxe Interior Panels than with the Standard Interior Panels?  Or is there only one rear seat bottom and back regardless of the interior panels installed for a Coupe?
69 Z28 RS X33 50 A 713 Endura Console Rosewood
Re: '69 Camaro Rear Seat
« Reply #1 on: May 19, 2015, 08:18:27 PM »
Welcome to the (new) site.
I think they are all the same top and bottom for a coupe unless you ordered the fold down seat, then you received different interior panels with arm rests and ashtrays.
« Reply #2 on: May 22, 2015, 04:07:04 AM »
if you mean 'only the metal parts - frame/springs', then I suspect they are the same, but I also suspect the foam and padding portions are unique between std and deluxe interior (I KNOW the front seat foams/padding are different for deluxe)..
my69Z28camaro
« Reply #3 on: May 22, 2015, 08:59:08 PM »
Sorry for the lateness of responding, a little emergency took top prioirty.  BULLITT65 answer explained what I was curious about. I though the standard vs deluxe rear seat might be the same and that fold down rear seat resulted in a narrow rear seat because of the armrest w/ashtrays.  But I was not sure.
