Author Topic: 1968 396 SS August Los Angeles Production?  (Read 10947 times)
FortLangleyBC
« on: May 16, 2015, 12:08:54 AM »
Good evening -
Were any 68 Camaro's produced in August at the Los Angeles plant?
I am looking at a 396 68 SS vin L300504 with a 08E on the trim tag. The holistic and other sites suggest that LA started production in September...
Any input would be appreciated :)
1969 Trans Am 400 335 WQ Cameo White
FortLangleyBC
Re: 1968 396 SS August Los Angeles Production?
« Reply #2 on: May 16, 2015, 01:15:46 AM »
Thanks Paul -
I guess the trim tag is fake...
Have a nice weekend.
68 Ragtop
« Reply #3 on: May 16, 2015, 03:50:48 AM »
Pretty sure I have seen legit 08E 1968 LOS tags before. That could be real, and a nice find if it is.
CRG can confirm if they have early 1968 tags, just wait for someone with data base access to respond.
CNorton
« Reply #4 on: May 16, 2015, 01:27:51 PM »
Would it not be possible for a car to have an August-dated trim tag although the VIN was reported in September.  I owned a Norwood-built '68 with an original 08C trim tag and the VIN 300200.  CRG does not report a month-ending VIN for August, 1967 at either plant but Fisher had to be building bodies before Chevrolet Division could produce cars.
« Reply #5 on: May 16, 2015, 01:35:19 PM »
I think the tag may be fine, and seems to line up correctly with the VIN.
I would like to see a better pic of the tag, since I am always a bit skeptical of A A paint codes.
My68SS
« Reply #6 on: May 16, 2015, 01:38:49 PM »
How do other build dates under the hood stack up? e.g. engine build, intake casting date, radiator tag if still there etc.
CNorton, can you post here or pm me a pic of your tag?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
68 Ragtop
« Reply #7 on: May 16, 2015, 03:00:01 PM »
I have another 08E tag number LOS00470 E299 in my data base.
FortLangleyBC
« Reply #8 on: May 16, 2015, 03:14:13 PM »
Good morning and thank you for the replies!
I have attached what I hope is a better photo of the trim tag as well as photos of the VIN tag, Rear Axle and Engine Pad Stamp.
The rear axle is BZ 2.73 non posi - does this make sense for a big block SS?
Any additional comments would be greatly appreciated :)
vtfb68
« Reply #9 on: May 16, 2015, 04:33:07 PM »
Paul,
 Yes, 08E is fine and legit. a friend of mine has a 08D L300245. our 08E IS L301025.
   Victor
68 08E LA RS Y2 749 L30 M35
vtfb68
« Reply #10 on: May 16, 2015, 04:46:07 PM »
Your car should also have a black ash tray and Astro windows. Drum front brakes?
  VT
FortLangleyBC
« Reply #11 on: May 16, 2015, 06:22:33 PM »
Thanks Victor
It does have a black ashtray & astro windows.
I am checking on the drum brakes - should they be drum or could they be disc?
What axle do you have in your 08D?
68 Ragtop
« Reply #12 on: May 16, 2015, 06:42:45 PM »
2.73 non posi would be the standard ratio for a non Rally Sport code MY engine.
« Reply #13 on: May 16, 2015, 07:51:36 PM »
Thanks Victor
Drum is standard in 68 for SS Big Block car. Disc would be optional.  http://www.camaros.org/suspen.shtml#Brakes
CNorton
« Reply #14 on: May 16, 2015, 09:26:47 PM »
I  sold the car about 15 years ago and no pictures of the engine compartment exist.  I believe that it was a base V8, manual shift car originally but I have no proof.  There was nothing stock in the drive train since it was a race car when I came into possession of it in 1979.  I raced it in Stock Eliminator from 1979 until 2001  It only had 14,000 on the odometer when I unhooked it.  The tick-roc tach was keeping perfect time until I removed the wiring harness.
c
