Hi all, seems like a lot of Camaro's suffered from bent in steel on the underside of the cross member from being jacked up in the middle [fore-aft] of the cross member, or being heavily bottomed out over road dips.
At least I haven't seen a un-restored flat bottom Camaro subframe cross member yet!
Any tips/tricks to getting this straight again? or is it just a case of trimming that section off with a cut-off wheel. pressing it straight then welding it back on, then grind and linish the weld.
Hate having to cut n weld things though.
Then again, it would give me a chance to clean up and treat the inside of the cross member.
