Author Topic: 67-69 Leaf Spring Shackles  (Read 18142 times)
« on: May 13, 2015, 09:57:10 AM »
Looking for confirmation on how to identify original assembly-line correct rear leaf spring shackles; I have a set which I believe are correct and they each have a letter stamped on the inside face. What other identifying features (other than shape) should originals have, and if there was more than one supplier, did those ID features vary?
Re: 67-69 Leaf Spring Shackles
« Reply #1 on: May 13, 2015, 11:46:17 AM »
Tim, look at Chick's build thread on Team Camaro as I know he had photos of his shackles for 68 at least.  I cant remember what the stampings were but they were stamped.
« Reply #2 on: May 13, 2015, 10:01:10 PM »
Thanks Darrell. Chick's shackle plates appear to be stamped with an 'S' on the outside face, whereas mine have a different letter ('B') stamped on the inside face, hence my original question.
I happened to notice a set very much like mine being offered for sale as 'correct', and just wondered if mine were original or not.
« Reply #3 on: May 14, 2015, 12:57:27 AM »
I think (which I might be wrong) that there were several suppliers for things like the shackles and I would bet they were stampings for different vendors..  Just an educated guess.
« Reply #4 on: May 14, 2015, 02:26:12 AM »
That would be my guess as well Darrell and as Tim noted mine did have a "S" stamped. Suppliers had a print that had to meet requirements so would think even different suppliers the part would be very similar but there is probably some type of abnormality but would probably take close examination. Will try to check some out and report back.
« Reply #5 on: May 14, 2015, 04:31:07 AM »
Thanks Chick!
luv2sixty9
« Reply #6 on: May 14, 2015, 04:24:44 PM »
"B" are known to be on Novas and "S" on Camaros
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
Camarocards
« Reply #7 on: May 14, 2015, 06:24:08 PM »
Tim,
Just as a follow on to what Chick reported in his build thread, my '68 also has an "S" stamped on the shackle.
I needed to replace the rubber bushings and couldn't find anyone that sold them separately. Seems like they were all bundled in with the shackle plates so I purchased the entire shackle kit just to use the bushings.
Below is a pic of my original shackles versus the reproductions. Dimensionally they are virtually identical:
Original GM
  Length: 5.355"
  Width: 2.278"
  Thickness: 0.191"
Reproduction
  Length: 5.345"
  Width: 2.245"
  Thickness: 0.196
I have just two observations on the reproductions:
1. The ends of the plate have a more pronounced radius where it transitions into the straight part of the plate.
2. I found no evidence of Zinc plating when I refurbished my originals.
Hope this helps!
Bob
« Last Edit: May 23, 2015, 06:45:45 AM by KurtS »
Bob
'68 SS L35 01D
« Reply #8 on: May 15, 2015, 05:44:51 AM »
Thanks Bob, nice comparison details.
« Reply #9 on: May 16, 2015, 07:11:16 AM »
Wondering if there is any difference in measurement between the hole centers for Nova and Camaro shackle plates, or are they the same? If anyone could confirm, that'd be great. For reference, my plates are 5 3/8" overall and the hole centers are 3 1/8" apart.
« Reply #10 on: May 17, 2015, 11:50:49 PM »
Tim, have not forgotten ya! Will work to check some cars out this week along with our 69 SS396 survivor we purchased new. See if I can see a stamping.....
« Last Edit: May 18, 2015, 12:26:09 AM by 68camaroz28 »
« Reply #11 on: May 18, 2015, 10:12:54 AM »
All good Chick, no hurry! Thanks ;D
HawkX66
« Reply #12 on: June 30, 2015, 02:30:31 PM »
Hey Tim, I just came across this post... Just in case you didn't get a definite answer to your questions, I can take a measurement tonight if you want. Here is my original 69 shackle. It looks just like Bob's 68 although not in as good shape...
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #13 on: July 02, 2015, 07:47:51 AM »
Thanks Hawk, a measurement would be much appreciated. I see your shackles are also stamped 'S' on the outer surface.
HawkX66
« Reply #14 on: July 02, 2015, 11:41:59 AM »
No problem Tim. I'll grab a few measurements when I get home tonight.
Dave
Semper Fi!
