Author Topic: Bulkhead Numbers and Letters ?  (Read 41935 times)
jdv69z
  • 69 RS Z/28 52E
Re: Bulkhead Numbers and Letters ?
« Reply #60 on: February 19, 2016, 08:13:13 PM »
So did the code also define the rear seat/carpet/interior trim that was to be installed, as Fisher did this part of the assembly?
Jimmy V.
crobjones2
« Reply #61 on: February 19, 2016, 11:30:06 PM »
I believe the numeral related to the X code.  There is not enough data to see if that follows
Chris
69 SS 350
« Reply #62 on: February 20, 2016, 05:16:52 PM »
Nope. X-codes were unrelated to the interior - they defined exterior features. Interior features/colors/trim combinations at Fisher were defined on the UOIT sheet (Fisher's version of a broadcast copy).
« Reply #63 on: February 24, 2016, 01:18:51 AM »
Clearly a small data sample but it does look like "X" for black interior trim paint and other color code letters for non-black interior colors (by exception).  Black interior trim paint was very common.
Yes black interior trim paint for all the houndstooth combos, black dlx blk std, white std,
711,712,713,714,720,727, & 729   - should use a X
715&716  -should use a B
718&719  -should use a R
723&725  -should use a G or DG
721&722  -should use a LG
Stingr69
« Reply #64 on: February 29, 2016, 02:03:05 PM »
I do appreciate this thread very much.  This question has been on my mind for decades and it looks to me like the answer is finally here.  Thank you to all that participated.
-Mark.
