Author Topic: Upper Control Arm  (Read 18169 times)
My68SS
Re: Upper Control Arm
« Reply #15 on: May 10, 2015, 03:01:17 AM »
So how do you tighten up the 'rivet-headed' bolts?
LOL, that's a good one Tim! Never used but know people that have so must not be an issue.
Agree 100% with Gary, that the car should be evaluated to see what other damage might be lurking or understanding why so heavily at that area.
Maybe they have a small spline under the head so it grips the metal? Like the upper control arm bolts.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #16 on: May 10, 2015, 08:56:25 AM »
I had a look at a few of the usual vendors' details and it seems the 'rivet' head end of the bolt is serrated to grip the hole.
Here's the link to just one such vendor's item, in case anyone else is curious:
http://www.camarocentral.com/1967_1969_Ball_Joint_Assembly_p/sus-36r.htm
« Reply #17 on: May 10, 2015, 10:29:37 AM »
« Reply #18 on: May 10, 2015, 12:47:51 PM »
Scott, see post above your last. Same link.
« Reply #19 on: May 10, 2015, 12:56:39 PM »
I never read page two of this thread so I did not see your post. I already assumed they made them like lug nut studs.  If I had to make my own because they did not I have a knurling tool for a lathe work.
Gramps69Z
  • 69 X33 D80
« Reply #20 on: May 10, 2015, 02:43:10 PM »
Brand new Camaro upper ball joint Rivet Bolt Set.  Mounts the upper ball joints to the upper control a-arm and gives it the appearance of a real rivet.
Captain John Wykoff
« Reply #21 on: May 11, 2015, 03:42:16 AM »
'gives it the appearance of a real rivet....from the top side'.    (they left out that last part!).. :)
lynnbilodeau
« Reply #22 on: May 22, 2015, 08:28:47 PM »
To the OP.  I have one good original upper control arm.  Don't remember if it is left or right.  Someone needed one, and I sent it to him a few years ago.
PM me if you don't find one, and I will check to see if it is the left.   If so, and if you still need it, it is free.   Just pay actual shipping which should be about $15.
« Reply #23 on: May 22, 2015, 08:36:51 PM »
Lynn, You are always so helpful to the hobbyist. This is bbbentley on sYc. I have benefitted from Lynn's charitable help. I say Thanks for this guy in advance and "Go Sox"!
dtep
« Reply #24 on: May 24, 2015, 12:55:20 AM »
Thank you Lynn but I think I have one on the way. I'll let you know either way how it works out.
lynnbilodeau
« Reply #25 on: June 20, 2015, 07:24:31 PM »
Just in case this comes up again.  Dick was unable to find a good rh upper arm.  I found the one I had, but it is lh upper.
I also have a pair of lower control arms.
All are available to anyone who needs any or all for their own car.   Just pay shipping.
