Author Topic: New 1967 find! Early VIN 7L100118 L6 3 speed  (Read 40764 times)
Top1motors
« on: April 28, 2015, 05:57:57 AM »
I recently picked this one up locally sitting in a garage for many years and found a hand written bill of sale from 1991 in the glove box. It appears to be from one family member to another (same last name). So I believe it to be a fairly untouched survivor. What I'm curious about is with it being the 118th Camaro built in Van Nuys, would it have been a "day one" car with that low number? Also it has a weird vinyl insert pattern on the seats. It codes as a 741 (red standard) and R-R (Bolero Red) car with only the 3K for any options. I worked in my fathers upholstery shop in the 1980's and know my way around seat repair etc. and these look to be original in every way I know to look for. Could this be a short lived vinyl option that was discontinued? Promotional colors? Also, where do I put the full VIN and trim tag info on this site for the registry?
68 RS restored (sold)
73 LT restoring
77 Son's resto
Top1motors
Re: New 1967 find! Early VIN 7L100118 L6 3 speed
« Reply #1 on: April 28, 2015, 06:09:42 AM »
A couple more pics of the red 67. Also, it does have incorrect 15 x 7 FW rallys and at some point had a V-8 4 speed installed (hole in tunnel and old dual exhaust still in car). Still has column shift in it.
73 LT restoring
77 Son's resto
CNorton
« Reply #2 on: April 28, 2015, 12:23:52 PM »
Body number LOS   889 is sitting in my neighbor's driveway.  The trim tag designation is 09C.  The pad stamp on the block was VO915.  If it is possible to determine the date when the Fisher line began produce bodies, it should be able to extrapolate the possibilities of your car being "day one."  What date does the trim tag on LOS   118 indicate?  Approximately how many days passed between #118 and #889?
Top1motors
« Reply #3 on: April 28, 2015, 02:07:54 PM »
The build date on my tag is 08D. So the trim tag looks like this:
   08D                                  S067
ST 67  12437      LOS      70    BODY
TR 741 Z                       R-R    PAINT
       3K
So 4th week of August and low body sequence #'s. Curious about the 741 Z (red standard vimyl and custom bucket seat trim?) what does that mean?
73 LT restoring
77 Son's resto
« Reply #4 on: April 28, 2015, 04:28:29 PM »
"741" indicated red standard bucket seats and "Z" indicated standard A50 Strato Bucket seats (no headrest).  Your interior photos above are not factory.
More info here...  http://www.camaros.org/numbers.shtml#InteriorColors
CNorton
« Reply #5 on: April 28, 2015, 04:44:01 PM »
I can't comment on the interior trim.  My limited decoding skills suggest that the car was optioned with "exterior molding group?"  The only other thing I can infer is that the car had a red, standard interior.
With regard to the Fisher body number "70", I would suspect that the car could have been either day-one or day-two.  Hopefully, others will offer opinions but you should review the information on "LOS - Fisher Body body scheduling code" found on the CRG page.  "S" would have corresponded to a particular day of the month (late in the month, commensurate with week "D".  As I interpret the explanation, the second part of the code "067" suggests that your car was the 67th vehicle that was started down the Fisher body line on that day.  CRG explains that the Van Nuys Fisher plant was producing bodies for vehicles other than Camaro and the numbers referred to ALL bodies begun on that particular day so, it would be likely that your car was very early in the day, especially when compared to other Camaros.
I owned a Norwood '68 Camaro that was tagged O8C and the VIN was 000200.  There were fewer different styles on the Ohio line and the production numbers were higher as well so I suspect that the '68 was a day-one car as well.
Mark
« Reply #6 on: April 28, 2015, 06:48:05 PM »
Body numbers from LA are tricky, just like to CA is a little odd. There are going to be four LOS 070 body numbers, or any other body number out there (within limits).  One from an standard interior coupe, one from a deluxe interior coupe, one from a standard interior convertible and one from a deluxe interior convertible.  LA ran 4 different body number sequences on the Camaros (and one can assume the other lines that they built).  the lowest vin for body number 070 would probably be on a standard interior coupe, deluxe interior coupe or standard interior convertible would be next, and the deluxe interior convertible would be latest.  LA built about 2600 deluxe interior convertibles, so for any body number higher than that theyre would be just 3 others out there with the same numbers.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Top1motors
« Reply #7 on: April 28, 2015, 11:14:45 PM »
Thanks for the input guys. I just got back on here after 4-5 years of not messing with Camaros but I'm back in! I may take the back seat apart and see if there is a GM part # sequence like i've found before on original upholstery materials. It really looks like it came that way. Could it be material from another car line from 1966 like Impala or Malibu etc? Is there any appreciable value added to these early VIN cars just for that fact or no? Thanks again!
73 LT restoring
77 Son's resto
« Reply #8 on: April 29, 2015, 03:26:30 AM »
If possible, can you take some photos of the underside of the trunk lid for us? There are some indications that the very early cars did not have emblems on the trunk lid and no access from the underside to attached the speed nuts for the emblems. Also, can you see it there were holes for 6 cylinder emblems on the front fenders under where the Camaro emblem would have been mounted? Thank you.
Top1motors
« Reply #9 on: April 29, 2015, 04:23:01 AM »
John,
Here are the pics. Also added the seat belt buckle style, trim tag and VIN plate. The fender emblem holes are from the driver side (could be L6 layout).There's quite a bit of distance between the "Camaro" and the other holes, height wise. Hard to tell from the pic.  Passenger side looks to be covered over with "bondo" as was the header emblem. But as you can see, there are access cut-outs for the trunk emblem and part of the original emblem is still attached. This car had one repaint of red and they didn't even do the jambs or inside the trunk. Still has jack instruction decal "glue" residue.
73 LT restoring
77 Son's resto
Top1motors
« Reply #10 on: April 29, 2015, 04:24:57 AM »
Last two pics of trunk emblem
73 LT restoring
77 Son's resto
L6Ragtop
« Reply #11 on: April 29, 2015, 04:26:37 PM »
The picture of the fender emblem holes doesn't look right for a 250 emblem.  There should be two holes level on the horizontal plane near the top of the emblem "shield" and one hole at the bottom of the emblem that bisects the line between the two upper holes.  The picture seems to show the bottom hole offset to the right of where is should be.  Of course, if the engine was originally a 230, there would not have been an engine call-out emblem.
Dan
« Last Edit: April 29, 2015, 04:55:02 PM by L6Ragtop »
68 Ragtop
« Reply #12 on: April 29, 2015, 05:02:32 PM »
It's not often you see the delivery date stamped on the VIN tag.
12/6 on an 08D built car is a long time when these cars where hot sellers in the fall of 1967
Top1motors
« Reply #13 on: April 29, 2015, 05:49:58 PM »
Unfortunately due to the engine and trans swap somewhere along the way makes me think previous owners may have tried to add an emblem on the drivers side. After examining the pass. fender closer it doesn't appear to have been messed with and there are NO lower holes. So that would indicate 230 L6 correct?
As for the 12  6 on the VIN, I had no idea that it denoted a delivery date. And does it mean sold to a customer on 12/6? Or could this car have been ordered by a dealer and left on display? Thus the long time between build and delivery or is the 12 6 showing when the dealer received it? Just want to be clear.
73 LT restoring
77 Son's resto
L6Ragtop
« Reply #14 on: April 29, 2015, 06:05:13 PM »
The lack of engine emblem holes certainly points to an original 230.
