ko-lek-tor,
I wouldn't mind a boost in power, but mainly I would like drivability. I currently have 4:10 gears with a T-350 that someone along the line stuck in the car and gas millage is awful. Little over 3000 rpm at around 50mph'ish. After I get the carb/intake part ironed out, I will try to figure out which overdrive trans to purchase and stick in to help with drivability and gas millage. At my stage in life, I would rather have a car that I can enjoy/cruise/take places; instead of hopping around short distances around town from time to time. My current intake it seems is a midrise cast unit and with the 3 inch open air cleaner on top the 4175, the top front of the air filter lid has cut into the hood insulation. I rather like the look of an aluminum intake instead of the painted cast; personal taste. I have read that the C396 intake would be a good choice but haven't seen one listed for sell. I would even like to go with an electric choke if I could. I like Holley as well, just not the one I have. Everything I read tells me that I would get better millage from a QJ carb. So with all this, which really isn't much; I was seeking you guys knowledge and thoughts be-for I proceed. Some of you guys has forgot more about this stuff than many of us ever knew!
L78 steve
I will research the 069 and 163 intakes, because I am not familiar with them. Might be silly question, but what brand, edelbrock, holley, GM?
