Author Topic: Engine part numbers for 67 350  (Read 9578 times)
crossram
  • Guest
« on: November 15, 2005, 02:37:54 AM »
I am in need of assistance for correct part numbers for starter motor (is it #1108389?) and water pump (last 3 numbers #326?) and did the oil pan have a caffle welded in on a 1967 Camaro 350?
67ss350camaro
Re: Engine part numbers for 67 350
« Reply #1 on: November 15, 2005, 12:46:05 PM »
Looks like the waterpump is ok.  I believe the starter should be 1108338.  Yes, there is a baffle in the bottom of the oil pan.
67 RS/SS 350 auto (owned since 81.)
97 V6 5-speed Coupe (work car ordered new)
2012 1LS (V6 6-speed) Coupe (new work car)
My Camaro
Steve68
« Reply #2 on: November 16, 2005, 12:51:13 AM »
I think the original equipment starter for your car had part number 1107365 and was stamped with either 1107365 or 1107388.  In January of 1970 the part was superceeded with 1108418 and went then to 1108400 in March of 1970..  Hope that helps you out.
