Author Topic: 69 Z28 Crankshaft number  (Read 27148 times)
Re: 69 Z28 Crankshaft number
« Reply #30 on: April 19, 2015, 10:33:28 PM »
So do we know what the difference between cranks is?
Improved/enlarged fillet radii on the rod journals, if I remember correctly. Side rod clearance or chamfer may have been altered (to accept the larger radii) as well to strengthen the rotating assembly under severe loads -
miket1
« Reply #31 on: May 09, 2015, 08:58:32 PM »
I sent Jerry M. my build date info. on this engine, he replied to me  it is very possible to have a 3279 crank carried over and installed in an Oct.5 , 1969 dated DZ engine', and the 68- 69  keyway is the same, so the 1969 style #7708 balancer and timing cover will work for correct timing.
It makes good sense that if the engine factory had a few extra 3279 crankshafts built up they would use them.
69 Z28 Burgandy
