Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
69 camaro dash pad peeling
« previous
next »
Print
Pages: [
1
Author
Topic: 69 camaro dash pad peeling (Read 6133 times)
69ZX77MP
Member
on:
April 06, 2015, 12:49:15 AM »
Hi my pad is starting to peal back form the front can I glue it, has anyone done this and what glue and info can they share thanks in advance thanks CRG
Tweet
Logged
1969 Z28 X77 Lemans Blue 03D
CRG Member
Re: 69 camaro dash pad peeling
Reply #1 on:
April 06, 2015, 12:40:39 PM »
If it is the original pad the plastic liner is probably warped and the vinyl has shrunk. I used Weldwood; it works for a while but will lift again shortly.
Logged
Kelley W King
Hero Member
Reply #2 on:
April 06, 2015, 03:05:26 PM »
I used super glue gell. I used the small black spring paper clips to hold it. You will need about 20 to move along as you glue. You have to use them along side each other as you go. It is nice to have 2 people to do it. Getting it out and is the hardest part. If you can borrow one to see where the studs are it is nice because if the car it intact some nuts you have to find them but you cannot see them.
Logged
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
69ZX77MP
Member
Reply #3 on:
April 07, 2015, 01:21:30 AM »
Thanks William,Kelley the dash pad is already out I like the idea of clips to hold it Any idea how many glue jells I might need thanks again
Morgan
Logged
jacmac
Member
Reply #4 on:
April 07, 2015, 11:04:03 PM »
About 5 trs ago I took my dash to a guy in town.He trimed about 1/4 inch off of the shell & then pulled the shrunken padding back around the shell. He then glued the padding back on,seemed to work pretty well.
Logged
BillOhio
Hero Member
Reply #5 on:
April 08, 2015, 02:49:21 AM »
I heard a guy trim is off also. makes up for what shrinks.
Logged
1968 RS 327 4 speed
Print
Pages: [
1
« previous
next »
Restoration
