Author Topic: Smog pipe  (Read 3673 times)
stovebolt
  • 1968 L6 Sport Coupe
Smog pipe
« on: March 28, 2015, 09:57:05 PM »
I'm gradually installing the smog equipment my '68 L6 originally came with. I don't have the smog pump yet but most everything else. My question is: could I install the pipe assembly and check valve but not the pump? Will the engine run normally? Will the engine require carb and timing adjustments? The carb and distributor are the original smog units. Thanks for any help. Joe.
