Author Topic: 67-69 Bumper Jack Design  (Read 165148 times)
« on: March 28, 2015, 02:28:31 AM »
I need your help to determine original bumper jack design differences between NOR and LA built cars.
My car's jack is MIA (no surprise, not much use on a race car) and so I have been trying to source an original 69 Camaro jack mast to fit my 04A build date (so aiming for '9C' on the rivet).
A member on another forum contacted me and stated that LA built cars used a different design jack to NOR cars. He advised that LA cars had a square section jack mast, and had no date stamp. I've only ever noted 1st Gen jacks with a trapezoidal section mast (and corresponding base) and a date stamp on the lever rivet. There has been some previous discussion about markings on the jack bases too, some owners have reported them blank, or with 'U', '69' or 'U69'.
The owner of a survivor early LOS Z/28 (09D of 1968) provided the following pictures of his car's jack, so a square mast design may have been used by at least some LA cars. Also note the end of the mast appears to have a date code ('8J' in this case, which fits with a body plate build date of 09D).
However, one data point alone means nothing, so I need more info from you guys - and photos (especially of the base) would be great! May as well open this up to all three years too.
What I'd like to know is:
Plant: LOS/VN or NOR
Model Year: 67, 68 or 69
Body Plate Build Date:
Jack Mast Section: square or trapezoidal
Jack Base: any letter(s) or number(s) stamped
Mast Date Code: location (rivet or mast) and actual date stamp
So here goes for the car to which the jack pictured below belongs:
Plant: LOS
Model Year: 69
Body Plate Build Date: 09D (1968)
Jack Base: nothing stamped
Mast Date Code: mast, 8J
And for the sake of clarity, here's a picture showing a jack base with the trapezoidal mast section (also note it is stamped 'U69'):
Re: 67-69 Bumper Jack Design
« Reply #1 on: March 28, 2015, 03:05:05 AM »
Tim, have you read this CRG thread?...  http://www.camaros.org/forum/index.php?topic=3681.0
« Reply #2 on: March 28, 2015, 03:19:55 AM »
At least 3 different bases were used.
« Reply #3 on: March 28, 2015, 03:23:07 AM »
Paul, yes I have. But that thread is old, certain links are inactive, and many of the contributors don't seem to be around still to provide all the info in a consistent format, hence why I started this.
blackss69
« Reply #4 on: March 28, 2015, 07:27:19 PM »
Between this post and the old post there will be a lot of really good information.  What would it take to make this a "research project" and get all the information together?  I'm sure it would be a lot easier for everyone to locate the correct information.
« Reply #5 on: March 31, 2015, 01:42:47 AM »
Maybe there aren't so many cars still with their original jacks intact? Any contributions would be much appreciated though.
« Reply #6 on: March 31, 2015, 12:58:45 PM »
I have the base from the L78 but my father broke the jacking mech back many years ago (used to break down tires off rims using the jack and car bumper) and replaced it with one from a 70 or 71 car IIRC..
« Reply #7 on: March 31, 2015, 07:36:55 PM »
Norwood 04D 68 Z.  Base is in with the " general population" of my parts...will look another day. Iron long gone :'(  here are my jack pics:
« Reply #8 on: March 31, 2015, 09:18:36 PM »
Norwood 04D 68 Z. here are my jack pics:
Thanks! Is the mast section trapezoidal or square?
« Reply #9 on: March 31, 2015, 09:20:15 PM »
Darrell, does the base have anything stamped on it?
« Reply #10 on: March 31, 2015, 09:35:19 PM »
trapezoidal
« Reply #11 on: March 31, 2015, 09:43:23 PM »
also no other markings other then UP.  No rust on it, just some rustproof splatter. Looks like an item that tends to be "over restored" I'm still floored what they ask price wise for these things! Used to trip over them in the junk yard. Going to continue it's life on the shelf.
« Reply #12 on: March 31, 2015, 11:11:41 PM »
Thanks janobyte, I'll add your details as a second data point.
Once (if!) we get a few more, I'll put the data into a spreadsheet and upload it to the cloud thingy like the one Kurt set up for the wiper motor research.
Plant: LOS
Model Year: 69
Plant: NOR
Model Year: 68
Body Plate Build Date: 04D
Jack Mast Section: trapezoidal
Jack Base: (to be confirmed)
Mast Date Code: rivet, 8D
« Reply #13 on: April 01, 2015, 01:55:36 AM »
Got a third data point from looking back through Darrell's thread on his barn find dusk blue X77:
Plant: LOS
Model Year: 69
Plant: NOR
Model Year: 68
Plant: NOR
Model Year: 69
Body Plate Build Date: 03B
Jack Base: U69
Mast Date Code: rivet, 9C
x66 714
« Reply #14 on: April 01, 2015, 04:02:58 AM »
Los
1968
02E
square
nothing on base
8B
Nor
1969
08E 1969
trapezoidal
nothing on base
rivet 9G
VE3 foot
This is what my cars have....Joe
