I have my original oil fill tube with PCV connection and wanted to try to use that and use my original chrome script valve covers (no baffles or holes for PCV/breather). I also have the old air cleaner with two tubes in the base.
I do not have the ventilator can in the block under the intake manifold or the connection at the back of the block. There is a freeze plug back there now.
Question is, am I limited to using aftermarket valve covers, which I have already, with a PCV (driver side) and breather (passenger side) until I get the ventilator and connector set up correctly or is there another way to ventilate the engine using my original parts? Thanks!
