Author Topic: rear brakeline  (Read 6647 times)
rear brakeline
« on: March 15, 2015, 11:07:08 PM »
looking for pics of 68 rear hard line to flex line ( from sub frame to bracket)  my rear floor pan has 2 clip assemblies. seeing 1 in the build manual. Also bends appear different? Original to car , never repaired or spliced. Single line from engine compartment. thanks.
Re: rear brakeline
« Reply #1 on: March 17, 2015, 11:13:11 AM »
As promised I sent you a couple pictures via email I took Monday afternoon while working on car.
Re: rear brakeline
« Reply #2 on: March 17, 2015, 02:12:03 PM »
thanks, sent a PM.
dannystarr
Re: rear brakeline
« Reply #3 on: March 17, 2015, 04:56:15 PM »
Are you talking about the line right near the tank? I always wondered why they couldn't come up with a better set-up, as that hose sure is close. If you need more pic's LMK...
Re: rear brakeline
« Reply #4 on: March 17, 2015, 05:15:29 PM »
off the rear sub frame--under body ( 2 clips) to the junction. (at bracket hard to flex line)   When I was "playing with it", the line got bent , not kinked luckily. Not a hard fix, but I need reference for the correct bends.  Waaay off right now.
