Author Topic: 1969 ce 302 short block  (Read 5945 times)
mls68z28
Mitch,1968 Z28 03C Norwood,03/18/68,Seneca Falls NY,Z/28 Emblems.Purchase 05/04/78
Re: 1969 ce 302 short block
« Reply #1 on: March 08, 2015, 03:06:32 AM »
Not 100% clear if the $1800 asking price is for the block, 1178 crank and pistons/rods (how many?), or just the block. Might even be a Tonawanda block.
RAfbody
« Reply #2 on: March 08, 2015, 03:28:26 AM »
The add states 302 short block which would indicate that the rotating assembly is included in the price. Still would want more detail about the parts.
Russ
« Reply #3 on: March 08, 2015, 04:29:26 AM »
Agreed. But the wording is not totally clear, and only the block features in the ad photos. I've contacted a number of sellers in the past only to find they think a "short" block means "bare" block.
So I would also not assume seller has 8 pistons and 8 rods too.
ds1
« Reply #4 on: March 11, 2015, 05:42:54 PM »
It is a complete short block
« Reply #5 on: March 13, 2015, 09:54:28 AM »
Are you the seller?
VINCE Z28
« Reply #6 on: March 13, 2015, 04:13:11 PM »
The seller states, sold as a package, not going to separate.I would think it's for all the parts.
« Reply #7 on: March 13, 2015, 04:19:32 PM »
'short block' to me indicates that it's an 'assembled' short block, with all internal parts, minus the heads and intake, and other peripherals.
If it's a short block, it is as assembled from the factory (with usage and age?), or is it a newly assembled (rebuilt) short block?
If it's not assembled, then he has the 'parts to assemble a short block'...
ds1
« Reply #8 on: March 13, 2015, 08:56:16 PM »
Yes it is mine.  I have not rebuilt it allowing the purchaser the opportunity  to  use the machine shop of their choice to do the work.  I know what it is like buying a used, rebuilt, engine.  This is a shortblock as I have known them to be sold.  It is completely disassembled.  Long blocks come with the heads,oil pans and usually  timing covers.  I  do not have those  parts.  I have an extra windage tray but no studs.  I have access to two bare cylinder heads but not matching.  The price is negotiable but as stated in my add I am not looking to separate it only unless some wanted the block.  Someone contacted me about the crank.  I have two cranks and they are not hard to get.  I have a 68 and have an engine for it.  When I put the  add on, I was at work  and only had access  to pictures of the block.  I  wanted to check the crank and see what it measured at.  I  never thought someone on here would pick up the add and run with  it.   Someone in my area had a wanted add for  an engine so I thought I would put it on. Check the ad again.  I have more pictures  of the parts
« Last Edit: March 13, 2015, 09:24:41 PM by ds1 »
